Surging ETZ 301
PostPosted: Sat Sep 06, 2014 3:19 am
by Andy_C
Any tips on reducing the amount of "surguing" that I experience on my ETZ ?
Bringing the tickover down as low as it will go and adjusting the air screw to something around half a turn out seems to minimise it.
Any suggestions ?
Re: Surging ETZ 301
PostPosted: Sat Sep 06, 2014 8:31 am
by DAVID THOMPSON
big 2 smokers are bad about that the 750cc suzuki 3 cyl..could drive you nuts in slow traffic
if your running a bit rich can cause it ..the excess builds up in the crankcase then burns off and leans out ..
then does it again ...
Re: Surging ETZ 301
PostPosted: Sun Sep 07, 2014 1:14 am
by Andy_C
David.
Had a fiddle with the air screw and tickover speed and have all but eliminated the surging now, still does it a bit but is tolerable.
I also run a Kawasaki 500 Triple which dosent surge at all, guess as each pot is fairly small you don't get the problem.
Cheers.
Re: Surging ETZ 301
PostPosted: Sun Sep 07, 2014 9:04 am
by DAVID THOMPSON
some of the multi cylinder bikes have a hose from the bottom of one cylinder to the intake of the other
it cleans out the bottom end of excess fuel
there was no dealer in my area for kawasaki till after the2 and 3 cylinder 2 smokers had came and gone
so not sure how its plumbing works
kawasaki arrived late in my area
