Gear shift shaft entrance leaking oil :(
Hello guys,
Unfortunately my ETZ 250 leaks oil out of the gear lever entrance..
Took a while to track it, as the whole gearbox seemed to leak out in the space of a month or two. Then after allowing it to sit, topping up with oil and cleaning the underside I've been able to get it down to the aforementioned hole.
Has anyone encountered this before?? To my knowledge, there isn't even any sealant or bearing supposed to be on there so I'm unsure how I will go about resolving this, but it isn't making my driveway happy. Nor my clutch too.
If any one has had this, what did you do to resolve it? Is it possible my clutch side casing has too much wear now on the hole?
