Front Brake light
Front Brake light
Postby badseed » Mon Apr 04, 2005 6:25 am
My front brake light does not work, it is most orobably about the switch since the light works with the rear brake pedal. Where is the switch for front brake light?
thx
rt 125
badseed
Postby micheleen » Mon Apr 04, 2005 7:37 am
It's screwed into the bottom part of the master cylinder casting underneath. It's just a mechanical switch I think.
Cheers, Mike
micheleen
where is master cylinder
Postby badseed » Mon Apr 04, 2005 9:32 am
Where is the master cylinder, do you mean the brake cylinder on the tire?
thx
rt 125
badseed
front brake lamp switch
Postby DAVID THOMPSON » Mon Apr 04, 2005 12:22 pm
9546517000 item 25 on pages fs06 J11
front brake switch sm sx and rt
rt on page fo6 J2 item 24
same number for all 3 styles of bike its mechanical not fluid pressere
Re: where is master cylinder
Postby micheleen » Mon Apr 04, 2005 12:44 pm
badseed wrote:Where is the master cylinder, do you mean the brake cylinder on the tire?
thx
No, the brake cylinder on the handlebars which the front brake lever is connected to :wink:
Cheers, Mike
micheleen
Postby jbthumper » Tue Apr 05, 2005 1:48 am
if the problem is a worn swith...u can tear the switch apart...and modify it instead of getting a new one(it's not cheap here where i live)...
it comprises of a spring, plastic rod(something like a ball pen tube)with a metal piece in the middle to touch a metal clip inside....
Check the switch...clean it if there's dirt...but if the problem doesn't go away u can try this....
u can use a ball pen ink tube,wrap a metal plate around the middle...put the whole thing in....adjust to you liking by cutting the tube shorter....WARNING...if u cut too short...u'll have to start all over again...
jbthumper
Postby sean18 » Tue Apr 05, 2005 2:53 pm
bit at the end of the plastic rod with a metal piece is likey to be worn away just turn it around a bit to make work thats wot i did and it fine at the moment
sean
sean18
125cc front brake light switch and fits saxon tour also
Postby DAVID THOMPSON » Wed Nov 08, 2006 10:03 pm
fits 125cc models and my saxon tour also fits made in italy HD 350 sprint
FOUND SWITCH AT BMW SHOP
BMW NUMBER= 61 31 1 244 070
FITS BUNCH OF STUFF
IF SHOP DOES NOT HAVE IN STOCK THIS IS AN ITEM THEY
NEED AT LEAST ONE
IN STOCK AT ALL TIMES
AS THERE ARE A BUNCH OF BMW MODELS THAT USE IT AND
THERE ALL GETTING OLD
$12USD PLUS SALES TAX
http://www.realoem.com/
http://www.realoem.com/bmw/partxref.do? ... &details=1
if above link does not work
Part Cross-reference
Part 61311244070 (STOP LIGHT SWITCH) was found on the following vehicles:
K53 R65 N/A, (0363) : HANDLE UNIT, RIGHT
K53 R65 N/A, (0364) : HANDLE UNIT, RIGHT
K53 R65LS N/A, (0365) : HANDLE UNIT, RIGHT
K53 R65 N/A, (0363) : HORN/RELAY/VARIOUS SWITCHES
K53 R65 N/A, (0364) : HORN/RELAY/VARIOUS SWITCHES
K53 R65LS N/A, (0365) : HORN/RELAY/VARIOUS SWITCHES
K54 R80GS N/A, (0348) : HANDLE UNIT, RIGHT
K54 R80ST N/A, (0349) : HANDLE UNIT, RIGHT
K54 R80GS N/A, (0348) : HORN/RELAY/VARIOUS SWITCHES
K54 R80ST N/A, (0349) : HORN/RELAY/VARIOUS SWITCHES
K56 R80 N/A, (0332) : HANDLE UNIT, RIGHT
K56 R80 N/A, (0392) : HANDLE UNIT, RIGHT
K56 R80RT N/A, (0448) : HANDLE UNIT, RIGHT
K56 R80RT N/A, (0448) : HORN/BRAKE LIGHT SWITCH
K57 R100/T N/A, (0393) : HANDLE UNIT, RIGHT
K57 R100/T N/A, (0435) : HANDLE UNIT, RIGHT
K57 R100CS N/A, (0436) : HANDLE UNIT, RIGHT
K57 R100RS N/A, (0316) : HANDLE UNIT, RIGHT
K57 R100RS N/A, (0395) : HANDLE UNIT, RIGHT
K57 R100RS N/A, (0437) : HANDLE UNIT, RIGHT
K57 R100RT N/A, (0399) : HANDLE UNIT, RIGHT
K57 R100RT N/A, (0449) : HANDLE UNIT, RIGHT
K57 R100RT N/A, (0339) : HANDLE UNIT, RIGHT
K57 R100/T N/A, (0393) : HORN/BRAKE LIGHT SWITCH
K57 R100/T N/A, (0435) : HORN/BRAKE LIGHT SWITCH
K57 R100CS N/A, (0436) : HORN/BRAKE LIGHT SWITCH
K57 R100RT N/A, (0449) : HORN/BRAKE LIGHT SWITCH
K57 R100RT N/A, (0339) : HORN/BRAKE LIGHT SWITCH
K57 R100RT N/A, (0399) : HORN/BRAKE LIGHT SWITCH
Postby EvanMac » Fri Nov 10, 2006 3:06 pm
If this is true then are there some BMWs that use the same levers and perches as the MZ?
EvanMac
lever
Postby DAVID THOMPSON » Fri Nov 10, 2006 9:45 pm
the parts book pictures at the above link look close
and i plan to check the lever on my rt125 on sat
yes SAT
if the dealer has that lever in stock
as the one on my saxon tour is bent a bit from a fall over while parked
??????32721242555 bmw ??????
but it may be wrong as bmw has always used magura as far as i know
the switch is a good number and have one in hand if i can find it in
the great abiss called my parts bin
see post on down the page
Last edited by DAVID THOMPSON on Sat Nov 11, 2006 3:03 pm, edited 1 time in total.
Postby jbthumper » Sat Nov 11, 2006 10:11 am
Hey guys,
just want to add... Aprilia(RS i think) brake lever will also fit BUT...they are of diffferent length(grip area) than our stock....
:smt033
jbthumper
found ?
Postby DAVID THOMPSON » Sat Nov 11, 2006 3:00 pm
brake lever link for those in usa
http://www.tryalsshop.com/detail.aspx?ID=48
i am going to check but i think this is it
but am lookin at only rt125 and saxon tour to compair
brakeL
Re: Front Brake light
Postby JonJoyce » Tue Apr 01, 2008 10:32 am
I managed to get hold of a switch from an older 250mz, it fits the same, good thing about mz is they have a good design and then stay with it! It cost me like £3 inc P&P and popped in, in about 5-10mins. Simply unscrew the front break leaver, pull the old one out and slide new one in, screw the lever back and and make sure you dont trap the rubber.
Jonathon Joyce
MZ RT 125, 2003
JonJoyce
Return to 125 cc
