backfire
backfire
Postby basser23 » Mon Dec 18, 2006 2:02 pm
Hey all,
The weather here was beautiful here in DC over the weekend, so I decided to fire up the Skorp to give it some excercise.....upon start
with choke on, it ran sorta ok,take the choke off, and have to give slight throttle to get it to run at all...backfires through carbs...not a bang, more of a puff noise ...will give large backfire through exhaust if revved and
throttled back rapidly..will only run if kept at 2k rpm....carbs?
Any guru help appreciated....yes fuel is fresh...has STA-Bil in it too..
Thank
Chip
basser23
crappy gas
Postby DAVID THOMPSON » Mon Dec 18, 2006 8:10 pm
sounds like a load of bad gas.. i ride mine to the store about 2 miles away
just to keep fresh gas in them even when it is very cold out
the gas they are selling us is nasty i try to put at least 15 miles a week on mine just to make room for some fresh gas
saxon tour and rt125
learned my lesson on a 71 bmw let it set 3 months one winter and it cost me
almost 300usd in parts to fix the carbs yuk the saxon tour has 1 of the same carbs ar dave
going out for a ride now 815pm monday night 48deg f here
Postby phlat65 » Mon Dec 18, 2006 11:37 pm
the carb sounds lean, probably plugged idle circuit. you should remove them and thoroughly clean them.
backfire
Postby basser23 » Tue Dec 19, 2006 8:57 am
Dave&Phlat,
Thanks for the info. The gas is fresh(less than a week),so I guess now that
its cold again,I can go outside and pull those carbs and clean away...argh..
Gotta love it...at least the weather here is not like in Seattle at the moment...
Chip
basser23
Postby phlat65 » Tue Dec 19, 2006 10:26 am
that was a good wind storm. the bad part, we had a lot of heavy rains prior, november was the wetest month ever on record, over 15.5 inches, so alot of trees came down and knocked out power. over 1 million people without power for at least 24 hours. the power just came back on at my work last night. gas stations are out of gas. the citys largest milk plant has been dark for 5 days, so there is no milk at the store. good times.....
basser23 new battery
Postby edec » Tue Dec 19, 2006 10:43 am
Basser23 please check your personal message box, Thanks-Ed :)
edec
Thanks basser23
Postby edec » Tue Dec 19, 2006 4:59 pm
Thanks basser23 :wink: edec
edec
Re: backfire
Postby AndyDent » Sat Apr 28, 2007 12:10 am
basser23 wrote:Hey all,
My Sport has always (since buying 2nd-hand about 6,000km ago) behaved like that - I thought it was normal, especially the backfires when you rev and back off quickly. I get backfires even when hot sometimes.
AndyDent
sparkplug
Postby DAVID THOMPSON » Sat Apr 28, 2007 10:23 am
review posts in this link
http://www.mzriders.com/mz/viewtopic.ph ... =sparkplug
may or may not help but sure made my saxon tour run better
:D
Users browsing this forum: No registered users and 80 guests
