Modified front end?
Modified front end?
Postby gedge » Thu Jul 08, 2004 3:17 am
Has anyone managed to change the front of their Baghira and replaced the headlight and all the scaffolding that keeps it up?
I figure that this weighs a lot and so would be interested to hear if anyone else has managed to bin the lot. Photos would also be reallly helpful :?
gedge
Re: Modified front end?
Postby Brian » Thu Jul 08, 2004 9:54 am
gedge wrote:Has anyone managed to change the front of their Baghira and replaced the headlight and all the scaffolding that keeps it up?
Check picts of Phlat65's he has a Acerbis Cyclops.......
"Brian" 2003 MZ Baghira
Brian
Postby gedge » Fri Jul 09, 2004 3:21 am
Thanks. I eventually found a pic of his bike... Looks great but there isn't much detail showing. do you think he could post( or email me) a close up of the Mods so that I can have a better look? Imitation is the finest form of flattery!
gedge
Postby cat-tard » Fri Jul 09, 2004 9:40 am
I don't have a photo of phlat's bike... but here's the acerbis photos/info:
http://www.acerbis.com/p107_headlight/3002.html
I may be interested in the original parts that you remove for this mod if you go through with it depending on what kinda $ you want - if you're willing to sell the stuff, of course.
cat-tard
Postby gedge » Fri Jul 09, 2004 10:13 am
That probably depends upon what the finished result looks like :roll: If it turns out okay I might sell them otherwise I may keep them until trade in time ......Could be expensive to ship though.
gedge
Postby phlat65 » Mon Jul 12, 2004 11:56 pm
i will do some detailed pics tomorrow for you! installed HID lamp and controler last weekend, you cannot miss this thing during the day, it is BRIGHT!
Postby gedge » Tue Jul 13, 2004 3:01 pm
Thanks I look forward to seeing the close ups.it will give me something to think about when I cant go out :( (.Just spent £6000 on wifes new car balance and then had to splash £400 on tyres for mine so I won't be doing much this month ...Ohh and I need spendies for my summer hols.).... skint again......
gedge
Postby phlat65 » Tue Jul 13, 2004 11:47 pm
check the pics, I cut the side panel suppurt tubes even,, moved the cap from the inside to the visible side. The headlamp is held on with the supplied rubber straps. made a harness, and zip tied it between the 2 bosses on the head tube so it does'nt catch when turning. there is not enough room to run the stock speedo, so I installed a Trailtech electronic speedo, which is great!
in one of the pics, you can see me holding up the wind deflector that came with the headlamp unit, I modified and installed 1 I got of a BMW650 at a motorcycle swap for $10.00. MUCH better wind protection, but still looks cool :twisted:
mounted lockhart phillips flush moun turn indicators on the hand guards, drilled through and ran the wiring on the back side.
last weekend added the HID lamp setup in the larger reflector, and mounted the controller under the right sidepanel.
any questions?
Postby phlat65 » Tue Jul 13, 2004 11:48 pm
the rest....
Postby gedge » Wed Jul 14, 2004 3:13 am
Thanks for the pics. Just what I needed to see.. Just need some cash and a bit of nerve to start cutting!!!
gedge
Postby DEmark » Wed Jul 14, 2004 5:37 am
Phlat,
Where did you get the Trailtech speedo? Is it illuminated? Is it like a bicycle speedo?- i.e. picks up the signal from a magnet you install on the front wheel, program the wheel diameter into it so its dead accurate. How much it cost? Do you like it? My speedo cable broke yesterday, I'm thinking about alternatives......
DEmark
Postby phlat65 » Wed Jul 14, 2004 9:52 am
under $100.00 at a motorcycle shop.
I like it alot, has alot of features..
http://www.trailtech.net/computer.htm
Postby DEmark » Wed Jul 14, 2004 11:16 am
I'm gonna order one up! Any idea which one (part #) you have?
DEmark
Postby DEmark » Wed Jul 14, 2004 2:34 pm
Phlat,
I just got off the phone with Trailtech, they have no idea which one to sell me. They need some more details.
How long is your cable? (I'll add 2" for my STD height)
How did the sensor mount? Screw to Caliper mount? Wire tie to fork leg?
What kind of magnet are you using? A magnetic disc bolt?
I hope you can help me out. They look like a good item to have....
DEmark
Postby phlat65 » Wed Jul 14, 2004 9:09 pm
got the universal, epoxyed the magnet to the right side of the hub, right at the spoke circle, and made a small "L" bracket for the sensor, bolted to the inboard axle pinch bolt, so the pickup is pointed at the magnet.
i will try to get some pics tomorrow for ya!
Users browsing this forum: Bing [Bot] and 149 guests
