Radiator Fan/Fans ??
Postby kendo » Mon Jan 29, 2007 5:20 am
Stupid question time, How many radiator fans should a UK Baghira have ?
I just have one on the LHS of the bike although the parts list shows two but i cannot seem to find the wiring for the other one under the tank which makes me think on UK bikes it is not required due to the average temp here, especially in Scotland.
Thanks in advance.
Kendo.
kendo
Postby keithcross » Mon Jan 29, 2007 3:51 pm
Only one fan is fitted to the UK baggi, on the left. So everything is OK then :)
Kieth
test run
Postby DAVID THOMPSON » Mon Jan 29, 2007 7:33 pm
unplug the fan and run it with a test lead every once in a while
so the bearings do not set up from lack of use
my rt125 fan has only came on once in 4 1/2 years
so i power it up once in a while to keep it loose
ar dave
Fan issues
Postby kendo » Tue Jan 30, 2007 6:15 am
Thanks guys, something else sorted.
kendo
RADIATOR FANS
Postby Chayanne » Sat May 05, 2007 3:42 pm
WHERE I CAN BUY THIS FAN FOR A SKORPION TOUR 2006 ?
Chayanne
Chayanne
parts
Postby DAVID THOMPSON » Sat May 05, 2007 6:41 pm
the parts guy
phil.albutt@bsa-regal.co.uk
if he does not respond in a couple days try a fax i think someone hacked his old address or spamed it
http://www.bsa-regal.co.uk
telephone and fax numbers on web site
THIS IS THE LOW HASSEL PARTS SUPPLYER
or mount one from a computer power supply
a supply from the early 1990's has them and most are 12volt
ar dave
Users browsing this forum: No registered users and 64 guests
