Need SKORP tail lens
Postby jimc » Fri Apr 20, 2007 9:16 am
Anyone know a US source for '96 Skorpion tail lite lens or cross reference?
Thanks,
Jim
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby basser23 » Fri Apr 20, 2007 2:17 pm
Jim,
I know that on MZOG@yahoo.com there is a parts reference list. You'll
have to join to access. I think the Buell is similar(on the Tour anyway)
I had broken one a few years ago,and got one from a racer as a take off.
Also i've seen some that use an LED type light..if mine goes again, that
is the route I'll take....
chip
basser23
Skorpion tail lite
Postby jimc » Fri Apr 20, 2007 3:23 pm
Thanks Chip, I'm thinking the Skorpion sport takes a different tail lens than the Traveller & Tour - Anybody know for sure? I'm also interested if anyone has located an LED type that might fit - this thing eats bulbs !!
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby basser23 » Fri Apr 20, 2007 4:01 pm
jim,
Quite sure you are correct, There are many types of LED lights available
on line.
You may want to try Airtech Streamling in Ca.,their online catalog has
a few lights that should work with a bit of niggling..
Chip
basser23
low voltage trick
Postby DAVID THOMPSON » Fri Apr 20, 2007 4:52 pm
here is one of my fav tricks to make 12volt lamps run longer
back to back diodes 7/10th volt drop per pair
1.4 volts 2 pair
see drawing below
ps makes bulbs in insterment clusters last a very long time
ar dave
low voltage trick.JPG (28.29 KiB) Viewed 2997 times
led lighting
Postby sokota » Sun Apr 22, 2007 8:28 am
check out wheelingcyclesupply.com for some kool led lighting options. [on edit , corrected spelling of wheeling :roll: ]
Scorpion Sport 660 ,Buell XB9SX , 71 BSA 500 MX , XR600 Motard
sokota
Postby bsmith » Wed Apr 25, 2007 7:23 pm
I Just got a stock taillight setup that I ordered from a local dealer 8 weeks ago, and they charged me out the arce $150.00!!! :shock: , but in the box was 2 lenses. I will sell you the other one if you want it. PM me if you're interested...
95 Skorpion Sport
74 BMW R90/6 (cafe)
73 BMW R75/5
71 Triumph TR6 (cafe)
bsmith
Postby sghonda » Thu Apr 26, 2007 11:04 pm
I dropped my lens (Skporpion Tour) and was able to fit the one from Guzzi V11 (converted to race bike for now...)
It seems Ducati Monter is using the same one too
Alan S. Honda
#881 WERA/CCS
sghonda
Users browsing this forum: Google [Bot] and 26 guests
