getting cooling fans to turn on at lower temp.
Postby m4panther » Thu Aug 23, 2007 3:54 pm
Anyone have an idea how I can get the thermostat on my 1000s to turn the fans on at a lower temperature? I think the fans should turn on sooner.
2001 Black Panther
2004 1000s
m4panther
Baghira fans
Postby edec » Thu Aug 23, 2007 7:00 pm
After 6 years of ownership, my fans went on last week for the first time- hot day and idling for a while in my driveway.
:? Ed
01 Baghira
99 Ducati SS750
edec
check
Postby DAVID THOMPSON » Thu Aug 23, 2007 8:31 pm
may have to check with phil at bsa
and see if any one has a temp sensor that kicks in at a few deg C lower
or wonk at slipstream
Re: getting cooling fans to turn on at lower temp.
Postby LWS66 » Sat Aug 25, 2007 11:30 am
[quote="m4panther"]Anyone have an idea how I can get the thermostat on my 1000s to turn the fans on at a lower temperature? I think the fans should turn on sooner.[/quote]
Can't help you on that one....How many bars show on the dash when moving? Mine shows four bars, even down in the south with 95+ degree temps as of late. At a stop all bars will light, but they never have flashed (which the manual says you should shut it down if that happens) My fans will run for short periods at idle, usually after a good flogging, but I'm not too worried. I'm running engine ice, before it was the factory coolant which I recall it running at five bars while rolling.
LWS66
Postby m4panther » Mon Aug 27, 2007 8:10 am
I changed to the engine ice also...I never got the flashing red bars, But I think it runs hot...My buddy has an aprilia mille and he had his swith changed to turn on sooner
2001 Black Panther
2004 1000s
m4panther
Postby m4panther » Mon Aug 27, 2007 8:13 am
2001 Black Panther
2004 1000s
m4panther
Postby iceman » Wed Jul 02, 2008 12:32 am
I realize this post is almost a year old but just wanted to say that i have a couple of Aprilia's and spend time on that forum and some members that feel that their bikes run hot wire a switch direct from the battery or fuse box up to the bars/clip ons then direct to the fans so they can control when the fans run.I have read this a few times on that forum...Just a thought feed them 12 V and they run.
John Lennon
iceman
Postby m4panther » Thu Jul 03, 2008 11:02 am
DAMN GOOD IDEA!!! Thanks
2001 Black Panther
2004 1000s
m4panther
Return to 1000S
Users browsing this forum: No registered users and 112 guests
