Rear Brake light
Rear Brake light
Postby badseed » Sun Jul 25, 2004 1:05 pm
My RT 125's rear brake light does not work. There is no problem with the front brake. How does the brake ligt work? I did not see any circuit cable around the brake lever arm. Is it triggered from an other place? There are 3 cables at the back of the light. One is ground and are the two others seperate for each brake signal?
Thx
Ugur
rt 125
badseed
brake light
Postby DAVID THOMPSON » Mon Jul 26, 2004 12:41 am
there is a switch on the rear brake master cylinder
mine went bad
short the wires together at that switch.. if the light comes on switch is probely bad
i recomend that you replace it with a mechinical switch of some kind
as i am still trying to get the air out of my rear brake system
older bikes had a switch and a pull spring and you dont have to
mess with bleeding the brakes
ar dave rt125 in wv usa
note at the tail lamp
one wire is groung usuall brown on german bikes
one is nite and day time run
and the brighter of the 2 filements is stop
rear brake switch
Postby badseed » Tue Jul 27, 2004 4:44 pm
I found the switch and short circuit the cable. The light came out. Then I took out the switch to clean inside with a needle. I put it back then checked if it works. It worked only two times. I realized that I did not tighten hard and the brake oil came out of the cylinder. I went to the service and fixed the brake problem. But then switch started not to work again. :? Did you get a mechanical switch, the guys told me that they have never seen a switch like that. I most probably will order a new one from http://www.mzparts.de. It costs 12euro or sthing like that.
rt 125
badseed
brake light switch
Postby DAVID THOMPSON » Tue Jul 27, 2004 10:32 pm
if you have a bmw dealer in your area show it to his part man
it may be the same on a bmw i will look to see if there is a bmw number
looking at my notes from past work on my bike
aprilia number on parts bag is 8124479
mz part number = 9013198000 brake light switch
german =bremslichtschalter
PAGE in MY Parts BOOK = FO9 B3 item 6
same page item 7
also order 2 of 9013199000 sealing ring (dichtring) or copper washer
i can email parts page if needed
you may have to force brake fluid through the system backwards
from the caliper end to get the air out i am still not happy with the feel of mine
show this picture below to your parts man
:smt023
word search rearbrakeswitch rbsw
Last edited by DAVID THOMPSON on Thu Feb 22, 2007 6:55 pm, edited 2 times in total.
Postby jbthumper » Sat Jul 31, 2004 2:09 am
Hi all,
I had the same problem with my rear brake pump on my sm....the swith works when the correct amount of presure(which is 5 bar for my bike)is applied through the pedal.....but when it leaks.....there won't be enough pressure....
what i did was i went to this aprilia workshop which a friend of mine recomended and changed the MZ switch with an aprilia switch....now it works fine.....(so u won't need to use those expensive BMW parts :-) )
hope this helps!!
jbthumper
Postby badseed » Sat Jul 31, 2004 3:41 am
Did the aprilla switch fit to the MZ? Or did you have to do some additional stuff?
rt 125
badseed
Postby DAVID THOMPSON » Sat Jul 31, 2004 1:08 pm
its a perfect fit
mine came from mzna in a aprilia parts bag
ar dave
Fixed at the end.
Postby badseed » Sun Sep 12, 2004 6:55 am
aprilia 8124479 is the original part. I paid 16euros and now rear brake light is working fine. :D
thanx a lot.
rt 125
badseed
Return to 125 cc
Users browsing this forum: Google [Bot] and 4 guests
