slipping clutch mz 150
Postby RRichiee » Sun Jun 01, 2008 7:48 am
Hello, the clutch of my MZ slips when I am accelerating. It suddenly started and I never changed anything to the engine. Who knows what I can do about it?
RRichiee
Re: slipping clutch mz 150
Postby DAVID THOMPSON » Sun Jun 01, 2008 10:32 am
is it one of the 2 smokers
and make sure clutch cable is not to tight
may need to replace the clutch plates also make sure you have the correct oil in the bike some oils are tooo slick for wet clutch
use
if you replace the plates do the springs also if bike is an old one over 10 years
Postby RRichiee » Mon Jun 02, 2008 7:08 am
it is from 1975 an it indeed is a 2 smoker
the problem is neither the cable nor the oil
I also tried adjusting the clutch screw with no results
I guess I should replace the plates and springs
thank you for your advice
Richard
RRichiee
Users browsing this forum: Bing [Bot] and 59 guests
