Starter clutch
Starter clutch
Postby vitesse7749 » Thu Jun 19, 2008 6:25 pm
Has anyone not had a problem with the starter?
Is this a matter of oil change intervals or other variables or is it just a very weak part.
I'm just trying to avoid the avoidable if at all possible.
Has anyone attempted a rebuild repair of the failed clutch or is this just wishful thinking.
Working on old British iron there are fixes that can be rendered.
R :shock:
vitesse7749
Re: Starter clutch
Postby DAVID THOMPSON » Fri Jun 20, 2008 7:02 pm
grahams in the uk and hope the have it
http://www.grahamsmotorcycles.com
if it becomes unobtainum i will see if i can think up a home repair
plus the thing likes lots of nice fresh clean oil
change oil and filter often
i use shell rotella t in 20-40 w
Re: Starter clutch
Postby vitesse7749 » Mon Jun 23, 2008 6:13 pm
Thanks muchly, I had a feeling the life was in the oil. The filter is a BMW F 650 I'm told. The rotella is mineral non synthetic? 20/40 is the correct weight? :shock:
vitesse7749
Re: Starter clutch
Postby DAVID THOMPSON » Mon Jun 23, 2008 8:29 pm
do not run bike backwards in gear and let clutch out with a stopped motor you will pop it
both times i killed mine going up a hill and stalled on wet grass and let the clutch out to stop my self
as front wheel brake was not stopping me this ran the motor backwards against the sprag killing it bang....
Return to 125 cc
