rodge70 wrote:brown is the earth return,2 wires for each indicator are the feeds and i think the feed for the warning light as well,if blowing fuses,check new lights are not earthed through there bodies if so swap wires over.only browsed over wire dia but seems straight forward job.
might be worth check new ones for continuity with out bulbs in them,ie no reading,good luck
Users browsing this forum: Google [Bot] and 21 guests
