baghira. tank/seat fasteners
Postby mr-brightside » Sun May 03, 2009 5:14 pm
i went out for a quick ride on the baghira today when i got home found out i had lost one of the fastners that hold the front of the seat on to the tank :( are these a special mz bolt ? or does aerotek dzus bolts fit ? ive searched the net but cant find one the exact size :roll:
mr-brightside
Re: baghira. tank/seat fasteners
Postby funmonkee » Sun May 03, 2009 6:04 pm
You can get them from grahams (google mz grahams). I got a full set for my '02 baggi, but I think the holes are gubb ed on my bike. beware those bolts are expensive...
funmonkee
Postby mr-brightside » Sun May 03, 2009 6:30 pm
expensive ? how much do you reckon grahams is just up the road from me i will pop in next week . but i was hopeing i could get some of those nice shiny d ring type fastners to fit but i dont supose that is going to happen as most of what ive seen look a bit short . what do you mean by your holes are gubb ed ?
mr-brightside
Postby funmonkee » Mon May 04, 2009 3:09 am
The repalcement bolt for under the seat and the two fasteners for the front of the seat cost me over £20 +postage
The holes here the fasteners connect are either worn or too big.
I'd be interested if you find a better solution than using the MZ OEM bolts. I currently don't have anything to keep the seat permanently attached to the bike...
funmonkee
Postby mr-brightside » Mon May 04, 2009 2:33 pm
i just orderd 6 from ebay for £4.50 inc postage not sure if they will fit yet but the size seems about the same ile let you know when i get them .
i supose if the insides are worn i could always get some of that liquid metal they sell in small tubes fill the holes a re tap it to 6mm .
mr-brightside
Postby mr-brightside » Thu May 07, 2009 3:36 pm
i got the fastners today but they didnt fit :cry: i didnt think i was going to be that lucky.
i think i will get some 6mm inserts from work and try and fit them in there i dont realy like them quarter turn fastners much anyway.
mr-brightside
Postby pontala » Tue May 15, 2012 5:38 am
I lost the under seat bolt on my baghira B.P. , I look every were and can find it, is any one can help me to were I can find the original bolt that goes under the seat?
pontala
Postby Baggy-trousers » Tue May 15, 2012 8:50 am
mr-brightside wrote:i got the fastners today but they didnt fit :cry: i didnt think i was going to be that lucky.
If you haven't got anything sorted yet send me your address and I'll send a spare one to you, I should have the right size ones here somewhere. (I contacted one of the main manufacturers/distributors of dzus fasteners and told them I was a business and needed a sample pack and they sent some to me for free!)
Baggy-trousers
Postby mr-brightside » Tue May 15, 2012 1:53 pm
thanks for the offer but im all sorted now (this post is 3 years old :D ) i drilled my fastners out and replaced them with 6mm nut inserts so i could use standard 6mm panel bolts . this would also work with the bolt under the seat but if you cant get hold of a nut insert tool you could just try superglueing a nut in there?
mr-brightside
Postby Baggy-trousers » Wed May 16, 2012 3:13 am
mr-brightside wrote:thanks for the offer but im all sorted now (this post is 3 years old :D ) i drilled my fastners out and replaced them with 6mm nut inserts so i could use standard 6mm panel bolts . this would also work with the bolt under the seat but if you cant get hold of a nut insert tool you could just try superglueing a nut in there?
:oops: :oops: I completely missed the date on this thread!!! Oh well, at least you're sorted. :lol:
Baggy-trousers
Postby cat » Wed May 16, 2012 4:17 am
:D Great stuff! :lol:
There is a thread - or two - on this. I vaguely remember Keith doing something about it. There were problems with the original fasteners being corroded and that led to people looking at various alternatives. I'll try to find that thread - if I find it, I'll add the link here.
PS: Many threads / many references to it: https://www.google.com/search?q=site%3Awww.mzriders.com+brake+light+switch
Just thinking...the screws falling out, that suggests that using Loctite would be helpful, but the problems with corrosion means using anti-seize.
What is a nut insert? And nut insert tool? :? I thought i had all tools. :roll:
cat
Postby mr-brightside » Wed May 16, 2012 2:35 pm
bit hard to explain but it sort of looks like an air riveter with a threaded bolt sticking out of it you just thread the insert on to the sticking out bolt then put it in the hole where you want your thread and press the trigger on the insert tool then the insert squashes up so its expanding on the outside griping the hole that you have just put it in leaving you with a thread for a bolt. hope that sort of makes sense
mr-brightside
Postby jitsushaun » Wed May 16, 2012 3:00 pm
hey baggy trousers ................u still got any of those spare fasteners?? i lost one last week and bike failed mot on 'insecure seat'.
if you have could you give me a price for one and i'll pm you my address. tried a dzus distributer just up the road from me, but they said they couldn't help me out!!
jitsushaun
Postby Baggy-trousers » Thu May 17, 2012 9:27 am
jitsushaun wrote:hey baggy trousers ................u still got any of those spare fasteners?? i lost one last week and bike failed mot on 'insecure seat'.
Pm me your address and I'll send one to you when I find them. Sorry to the person who pm'd me but I only have a few and I'd rather they stayed in the U.K!
Baggy-trousers
Postby handsomejackuk » Tue Jun 11, 2013 6:48 am
bump,
Baggy trousers, do you have anymore of those fasteners, or would you be able to tell me where to get them from ?
Al.
handsomejackuk
Users browsing this forum: No registered users and 126 guests
