95 Skorp Sport left handlebar control
Postby dotacion » Fri May 29, 2009 12:30 pm
Hello to everyone-
I haven't visited mzriders in awhile, but I've had my Sorp for ten years.
It's been in hibernation for the last four. I am in the process of getting it roadworthy again. Already got it started, and it sounds great. Got a whole list of things that need attention.
Once the carb was cleaned out and the choke adjusted, found a prob with the bolts that screw the two plastic halves of the left handlebar control. Can't tighten; thread appears to be stripped.
Is there a fix for this? Or is finding a replacement a reasonble alternative?
I'm in Pasadena, CA.
MikeS
dotacion
Re: 95 Skorp Sport left handlebar control
Postby jimc » Sat May 30, 2009 6:02 pm
Have a look at helicoil repair.
Providing you can drill straight and the threaded area isn't cracked.
http://www.helicoil.in/index.htm
This would be a permanent fix better than new.
Most any fastener supply place or good hardware or auto parts will stock these.
Good Luck......
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby DAVID THOMPSON » Sun May 31, 2009 8:19 am
think its plastic
fill with plastic repair called Qbond and drill out i think screws are sort of self taping
if need i can get web address from store here that sells it
also you may be able to drill hole on threw and use a nut and longer screw
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
