by funmonkee » Sat Jun 13, 2009 11:26 am
Grrr, I attempted to switch over to a newer rear sprocket and found that 2 of the rear sprocket bolts are rounded...Grrr
Has anyone got some ? Name your price. Thanks
PS Anyway got a quick way to get these buggers out when they're rounded?
funmonkee
by Stuart109 » Mon Jun 15, 2009 7:55 am
Hi
If I remember correctly a couple of mine sheared off trying to get them out. I removed the wheel and took out the drive. The bolts protruded through the back and I was able to get a grip on them to unscrew them.
I replace the Allen bolts with hexagonal head bolts.
Stuart
Stuart109
by funmonkee » Mon Jun 15, 2009 1:12 pm
cheers dude, that sounds like a plan. do you have any spare hex bolts that fit? I could never get the correct pitch for those bolts last time this happened...
funmonkee
by ronny60 » Thu Jun 18, 2009 1:19 pm
Hello ,
The exact dimensions are M10x40 ( Pitch 1,25mm) with hexagonal head.
The original ones seem to be of a real poor quality.
For removing you better heat them.
Today I ordered a new chain and sprockets and I real hope I don't run in the same problems .
Grz,
Ronny
ronny60
Users browsing this forum: No registered users and 217 guests
