Gedge !
Gedge !
Postby bigzed » Thu Nov 04, 2004 3:04 pm
Or anyone else with a motrax led tail light,some wiring help needed,i'm shit with 'lectrics :? but i fitted said led light and i don't have a no plate light can you fill me in on the wiring please.Many thanks in advance.
Gary
also fitted acerbis diamond h/light which surprisingly does work :D
bigzed
Postby gedge » Thu Nov 04, 2004 3:21 pm
Gary
On the UK models of the LED the lower section is clear and when the side light is on, it shines white light down on the number plate.. it doesnt have seperate lighting wiring.. Just make sure you didnt put it on upside down so that it lights up inside the rear fender :D
gedge
Postby hulagun » Thu Nov 04, 2004 5:01 pm
Anybody in the UK that can sell me a couple of those Motrax LED taillights? we can't gettem here except in all clear (with red LED). Clear stoplamp lenses don't appeal to me.
Ivan
hulagun
Postby keithcross » Thu Nov 04, 2004 5:19 pm
Cant create the link, but a guy had one of the units you want for sale on ebay a while ago. It might be worth trying to contact him. The item number was 7928432663.
Update, try item number 7930823603. Light is available with either red or clear lens.
BTW with the one currently connected, have you got it wired right. Doe the numberplate light work with the brake light. You may have the tail light/brake light connections reversed.
Postby bigzed » Thu Nov 04, 2004 6:07 pm
When i put the lights on i get quite a dim glow,pull the brake it goes very bright but i don't got no white light at all for the plate must be a wire in the wrong place methinks :oops: . Cheers Gary
bigzed
Postby gedge » Fri Nov 05, 2004 8:24 am
bigzed wrote:When i put the lights on i get quite a dim glow,pull the brake it goes very bright but i don't got no white light at all for the plate must be a wire in the wrong place methinks :oops: . Cheers Gary
I am not sure what you have done.. There are only 3 wires IIRC. 1 Sidelight , 2 brake light and 3 earth....
The Red lEDs glow pretty brght on side lights and then reallly bright when you brake. Part of the lens cover is clear and the leds above this are white, they shine onto the number plate......hope this helps :D
gedge
Postby bigzed » Fri Nov 05, 2004 1:46 pm
Ta mate,so simple but i just can't get my head round it :roll: hopefully get it sorted tomorrow, when she goes in for an oil change. Cheers the noo Gary
bigzed
Postby micheleen » Fri Nov 05, 2004 2:24 pm
Brake and earth wires crossed :?:
Cheers, Mike
micheleen
Users browsing this forum: Bing [Bot], Google [Bot] and 28 guests
