valve clearances please.. 660 baghira ?
Postby handsomejackuk » Thu Sep 03, 2009 5:26 pm
as topic says, can anyone remind me of exhaust, and inlet valve cleareances.. ?
also did read somewhere that by giving bit more clearance, that engine will be a bit more peppy..
standard clearances please
Alun
handsomejackuk
Re: valve clearances please.. 660 baghira ?
Postby Bill Jurgenson » Thu Sep 03, 2009 11:36 pm
.10mm in
.15mm out
both cold
.05mm more if hot
Postby handsomejackuk » Fri Sep 04, 2009 3:28 pm
bill,
thnaks for that, will check them tomorrow......
Alun
handsomejackuk
Postby DAVID THOMPSON » Fri Sep 04, 2009 6:46 pm
Bill
would this also apply to my 1997 traveller
by the way its running better after fixing a bunch of things
i found wrong
so valvesa are some thing i need to check as it is now at 7200 miles
Postby Bill Jurgenson » Sat Sep 05, 2009 5:19 am
obviously, it applies to every Yamaha xtz engine ever made.
Has nothing to do with which MZ model or if it is one of the many Yamahas with one of the many derivative engines - or the Aprilia with that engine...
