Plastic Chain Guard Necessary?
Postby comanche91 » Wed Oct 21, 2009 6:01 pm
When I got my SilverStar, it was missing the upper and lower middle plastic chain guard pieces. I've adjusted the chain, but it still slaps on the guard around the rear sprocket, especially when the engine is lugging below 3K RPM. Is this piece really necessary? Looks like the speedo cable screws into the rear piece too, as shown by the arrow. If I remove it can I still hook up the speedo cable? Thanks; Don
-Don
1-3/4 1995 Silver Stars
comanche91
Re: Plastic Chain Guard Necessary?
Postby DAVID THOMPSON » Wed Oct 21, 2009 9:12 pm
have not had mine that far apart can probably run with out it
but back to original means longer chain life and a much cleaner bike
some one in the uk tell him where he can get the rubber tubes
Postby djsbriscoe » Thu Oct 22, 2009 6:13 am
Normally there are two rubber chain hoses/gaitors attached to the sprocket cover, these absorb any chain slap. Do you still have these?
New ones can be obtained from
Spares & Repairs
MZ House
20 Peregrine Close
Winsford
Cheshire
CW7 1SH.
UK
Tel +44 01606 593638
Or Burwins in London (who probably gets them from Fred Rogers anyway).
The sprocket cover contains a small worm gear that engages with a gear wheel on the sprocket/cush drive carrier. I'm not sure how you could arrange for alternative speedometer drive apart from an electronic sensor on the front wheel and a bicycle computer.
Is this what your asking?
David.
Electronics tech by trade.
djsbriscoe
Postby comanche91 » Thu Oct 22, 2009 1:23 pm
Are these what you are referring to David? I do not have them, have never seen any, and they didn't come w. the bike. I ASSumed they were plastic. If they are rubber, I can see how they could take care of chain slap. To install these I'm guessing, the chain must come off under the front sprocket cover then rethreaded thru the new rubber pieces after installation then hooked back up and adjusted?
-Don
comanche91
Postby djsbriscoe » Thu Oct 22, 2009 4:10 pm
Yes, those are what's needed but you'll have to make sure they are for the silver star as they are also used on all the early 2 stroke MZ's as well. Might be all the same length or different depending on the bike. I used to use a straightened out wire coat hanger with a small hooked end to pull the chain through the rubbers and then join the chain at the engine sprocket with the cover off.
David.
djsbriscoe
Postby manumensa » Thu Oct 22, 2009 5:23 pm
Hello Don.
Absolutly recommended rubber chain guards.
I was thinking open a oil hole my rear sprocket guard-same model in your SilverStar (bakelite)- when I saw
a Bultaco Metralla guard.
Observe the correct oil hole position. centrifugal force make the work.
Problem, I have not good accessibility to rear sprocket guard because same side exhaust and a bag.
No problem for Bultaco: right side exhaust left side chain.
Saludos/Regards.
manumensa
Postby comanche91 » Thu Oct 22, 2009 6:41 pm
Thanks manumensa, I'm trying to run down a set now. I didn't even know they were rubber and functioned as a chain guide because they were missing on my Silver Star. I don't know how long they have been missing, but the chain has chewed up the rear sprocket guard a little bit. That Metralla is a beautiful Bultaco. Will that rear sprocket guard in your picture fit a Silver Star?
-Don
comanche91
Postby manumensa » Thu Oct 22, 2009 7:35 pm
Don, unfortunately not compatible size and
you need connect speedometer drive cable in
a MZ sprocket guard.
Price Bultaco aluminium sprocket guard also hight: 190€!!
manumensa
Postby comanche91 » Thu Oct 22, 2009 7:51 pm
manumensa wrote:Price Bultaco aluminium sprocket guard also hight: 190€!!
OUCH! Hopefully I can find a set of Silver Star chain rubbers that won't break my bank.
-Don
comanche91
Postby comanche91 » Fri Oct 23, 2009 9:33 pm
Recieved a reply from a vendor that stated the ETZ 250/251 and larger cc ETZ chain rubber tubes would fit the Silver Star, as they both use the same chain. Can anyone verify this? Thanks; Don
-Don
comanche91
Postby comanche91 » Sat Oct 24, 2009 3:04 pm
comanche91 wrote:Recieved a reply from a vendor that stated the ETZ 250/251 and larger cc ETZ chain rubber tubes would fit the Silver Star, as they both use the same chain. Can anyone verify this? Thanks; Don
In investigating this further on the German MZ forum, the ETZ rubber tubes will work for the 500cc bikes, however the ID of the tube is slightly smaller than the original and causes friction, heat, and premature wear. And the original tubes for the 500cc bikes are no longer available. So it appears I'm screwed. I have a call into Fred Rogers in the UK and he thinks he can find some. I'm hopin' he can................
-Don
comanche91
Postby djsbriscoe » Sat Oct 24, 2009 4:26 pm
As the rubber tubes normally accumulate a lot of grease/oil I can't imagine it will wear out any sooner than the wider type. These gaitors normally crack at the corrugated ends after a while anyway. They will afford some protection to the chain and the swinging arm. I'm assuming it was Martin at Burwins who suggested the ETZ ones as being suitable? Why not buy both types to make sure.
Something else you could do is ask on the MZ_RIDERS yahoo group
http://groups.yahoo.com/group/mz_riders ... =330951138
to tap their collective wisdom. Many people on the above group have been around for many years and are real MZ enthusiasts.
David.
djsbriscoe
Postby comanche91 » Sat Oct 24, 2009 5:39 pm
Thanks David. Burwins, the AKF Shop in Germany, and the German MZ forum guys all stated that the larger ID 500cc gaitors (is that like out Gator? :D ) are not available anymore, even reproductions. Fred said he thought he had some and will call back Monday. So if Fred comes through, I'll get the correct ones from him and be in business. If he does not, then I'll get a set of the ETZ gaitors. But thanks to all the posts here, I do realize I should definitely have them installed. I'll check with the MZ_RIDERS Yahoo group too.
-Don
comanche91
Postby manumensa » Sat Oct 24, 2009 6:49 pm
Another opcion with this guy in Miami:
viewtopic.php?f=13&t=3689
manumensa
Postby comanche91 » Sat Oct 24, 2009 7:13 pm
manumensa wrote:Another opcion with this guy in Miami:
I started corresponding with him (Disney) a few months back; now he doesn't answer emails anymore. Image
-Don
comanche91
Users browsing this forum: No registered users and 109 guests
