lcrken wrote:I'm running the 860 cam in my Saxon Tour, along with a Ron Wood big bore kit, Axtell head, and 45 mm Mikuni. It's a blast, but only if you keep the rpm up. It refuses to carburete well at low speeds and small throttle opening. I wouldn't recommend it for anything except a hooligan bike (or a race bike). I used it because I already had all the parts laying around from my race bike, and thought it would be fun to do an over-the-top engine for the street.
Ken
Nozz wrote:I thought HMMNZ may be referring to the extra lift causing interference if a belt broke with a valve open. That sounds like another ron wood question.
DAVID THOMPSON wrote:trust me bent valves are no fun if you loose a belt 500 miles from home doing the belt on the road is a pain
hauling one home in a rental truck because you bent a valve is a big pain in the pocket book
