a 10mm spanner
a 11mm spanner
a set of feeler gauges (metric)
a spark plug spanner
a flat head screwdriver
and what ever tools you need to remove the tank
![Very Happy :D](./images/smilies/icon_biggrin.gif)
1. remove tank
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2693Medium.jpg)
2. unbolt the decompression lever bracket
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2694Medium.jpg)
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2695Medium.jpg)
3. with a 10mm spanner remove the rocker covers (2)
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2697Medium.jpg)
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2700Medium.jpg)
4. undo the spark plug (with the decomp lever gone, you need the plug out to turn the engine over by hand)
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2701Medium.jpg)
5. turn the engine to top dead center.. supposedly you can see a little white mark through the peep hole which indicates it there..
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2703Medium.jpg)
i can't
you don't have to be super accurate with this basically somewhere between compression and expansion (power) where neither cam lobe is pushing on the rocker arm
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/4-Stroke-Engine.gif)
6. now we are going to set the clearances (i saay set, because its just as easy to straight out set them, as it is to check them) on cam over bucket over shim engines or cam over shim engines you have to check and record the clearances before you change the shims so you know what new shim to insert... but no need to worry about that with the super simple rotax lump
7. loosen your inlet tappets with a 11mm spanner .
with your 0.05mm feeler (or for you americans ... 0.05mm
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2708Medium.jpg)
slip it between the tappet and the top of the valve stem,
8. with your spanner on the lock nut and your feeler in place, tighten the tappen with your flat head screw driver, untill it becomes tight, then back the screwdriver off a wee bit. the feel should be able to move but you should feel the resistance of the tappet.. you'll know what i mean when you do it
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2713Medium.jpg)
9. do the other tappet, and then move to the exhaust
10. the exhaust side, now this is where a debate could start, the manual states 0.05mm for both exhaust and inlet clearances, its not a misprint, thats what rotax recomends, but i still do the exhaust at 0.08mm simply for the fact there is more heat on the exhaust valves and therefore move valve expansion, so any where between 0.05mm and 0.1mm is fine,
if you ride your mz hard then i recommend 0.1mm if you ride it nicely then i recomend somewhere between
![Image](http://i58.photobucket.com/albums/g257/hmmmnz/mz/DSCF2714Medium.jpg)
and thats it, set your exhaust clearances to what ever you decide, make sure all your lock nuts are tight, chuck the rocker covers back on, connect the decomp cable, and your good to go
have fun
![:smt006](./images/smilies/006.gif)
