Brembo P4 30/34 caliper is too wide on Baghira?
Postby cat » Sun Jul 04, 2010 3:51 am
As per subject line:
Is the Brembo P4 30/34 caliper is too wide on Baghira?
Baghira, not Skorpion. Try as I might, reading and searching for hours, I have not been able to get a definitive answer.
Could we not just get a clear list of what fits, what is actually available and where...?
cat
Re: Brembo P4 30/34 caliper is too wide on Baghira?
Postby Bill Jurgenson » Sun Jul 04, 2010 3:58 am
probably not, but doesn't fit without an adapter plate, same as on a KTM.
A friend rides a tuned Baggi. I'll ask him.
Postby Bill Jurgenson » Mon Jul 05, 2010 11:50 pm
I was right about KTMs. With spoked wheels there is lots of room and replacing the the floating caliper with a P4 is a favorite "past time." The milled adapter is easily gotten and the situation cannot be any different with a Baggi with spoked wheel.
Postby cat » Tue Jul 06, 2010 3:37 am
Thanks, Bill. Given that one does have to use an adaptor mount, that moving it further away from the mounting points on the forks also moves away from the spokes at the hub. I think I'd originally thought that they mounted directly to the [40mm] mounting points on the forks because I'd confused it with what I'd read abuot doing it on Skorpion. (That the Skorpion has the 40mm distance mounting and the Baghira does not...?)
cat
Users browsing this forum: Bing [Bot] and 32 guests
