baghira
baghira
Postby dazlandy » Mon Nov 01, 2010 4:33 pm
hi chaps
just bought a 2005 baghira , love the bike although it doesnt seem as tall as it should be (not worn , only 2000 miles)
think it may be the "hr" stumpy version , any ideas on how to "jack it up" , i cant seem to figure out how to adjust the ride height , as i am a heavy weight over 6 foot tall, i could do with the extra height on the bike, i have been told there were rear suspension linkages available to alter the height .
any advice would be very gratefully recieved
cheers
daz
dazlandy
Re: baghira
Postby dave » Tue Nov 02, 2010 9:55 am
Post up some pics if you can, or measure seat height and/or dogbones and I'll compare it to mine.
Most likely longer dogbones on it to drop seat height. Should be able to get some standard ones or get a local engineer to knock some up.
Re: baghira
Postby angustoyou » Tue Nov 02, 2010 3:41 pm
I´ve got the HR Baggy too, but it suits my little legs.
They use a 2"shorter fork (with no adjustment, that´s the give away) and a shorter rear shock.
The only way to pop it back to full height is replace the forks and shock off a full height one. :(
angustoyou
Re: baghira
Postby dazlandy » Tue Nov 02, 2010 5:34 pm
thanks guys
it seems you are right , they are shorter forx and shock (the dogbones are standard 120mm centre to centre)
although i may be able to make a couple of "slugs" for the top of the forks to allow them to slide down in their clamps, and i am considering making an extended mount for the shock (same travel but overall length increase ) a bit drastic but i need it to be higher !,
i think it may have the shorter masiff suspension parts ! ......the cause of confusion was that i read that the seat height was adjustable !......not true !......dont suppose anyone got a pdf of a manual ?,,
info on these bikes is a bit scarce !
cheers chaps,
daz
dazlandy
Re: baghira
Postby breakwellmz » Wed Nov 03, 2010 10:53 am
Why not get the seat refoamed?Best thing i`ve done to my Mastif.More comfort and the seating position i wanted.I`m 6ft and 14 stone.Cost me £100.
Re: baghira
Postby angustoyou » Wed Nov 03, 2010 5:00 pm
Your mods sound the best way to go Daz, if you're a bit handy and got access to the metal and the tools to work it. :D
The forks will be the tough bit. :?
angustoyou
Re: baghira
Postby dave » Fri Nov 05, 2010 11:27 am
If you're in the uk, you could have a word with a lady called Kayla at www.projection-components.co.uk.
She can make dog-bones, shock mounts etc to suit. Just a small home-based business.
Tell her Dave from the TRX850 forum sent you!! :wink:
Re: baghira
Postby dazlandy » Sat Nov 06, 2010 12:12 am
thanks chaps,
took the bike out for its first proper run yesterday.......wow ! that was fun......big singles dont much like trundling along in top gear at 25mph do they......bit lumpy .......drop a couple of cogs though and ..yipee !!GET OUT OF THE WAY I'M COMING THROUGH !!!!!!......COUGHT ME BY SUPRISE A BIT !........its a tad nippier than me old kwak gt550 ....
and it goes around corners ! never had a bike that goes well in two axis !!(straight & bends).....still got to raise her up a bit though......watch this space...... :twisted:
dazlandy
Re: baghira
Postby dazlandy » Sat Nov 06, 2010 12:18 am
er...chaps... would any of you baghira owners be able to take a couple of measurements for me ? i got a short-arse baggy needing elevation, i would be gratefull for the distance between the front axle and the top of the fork leg / upper surface of top clamp , also the distance between mounting eyes of the rear shock, ((both "off load" fully extended)
many thanx
daz
dazlandy
Re: baghira
Postby Anders » Sat Nov 06, 2010 4:28 am
dazlandy wrote:thanks chaps,
In reality the 660 5-valve is an engine designed to run high revs, grabbing a handful of throttle below 2500 rpm is asking for trouble (enginewise) and if you at any point feel that it is a bit lumpy, chain snatching etc the revs are too low.. actually it runs best around 4000 rpm.
Essentially; Keep the revs up and the engine is bulltproof, however riding it like a single from yesteryears it will break down...
In my garage:
Honda VTR 1000F -00
Orion-29 125cc, Midsize
49cc Bike engine kit toy
Yamaha SRX-6 -86
MuZ Skorpion 660 -95
Polaris 6x6 Big Boss
Nordic SRX/MuZ/SZR forum
Anders
Re: baghira
Postby edec » Sat Nov 06, 2010 5:14 pm
Anders, would grabbing a handful of throttle in 1st or 2nd gear under 2500rpm be harmful to the engine?
Thanks, Ed
01 Baghira
99 Ducati SS750
edec
Re: baghira
Postby DAVID THOMPSON » Sat Nov 06, 2010 5:52 pm
my traveller is not a very happy bike below 3000 rpm and does not seem to really work
correct till 3800 and up
and my rear sprocket is a 43 tooth it had a 39 on it when i got it last year and was geared
way tooo tall for how i use it
almost all roads my area are posted 45 mph just a few 55mph and only 2 60 or higher
so its real easy to get speeding tickets with a bad running 125cc bike
Re: baghira
Postby Anders » Sun Nov 07, 2010 4:04 am
edec wrote:Anders, would grabbing a handful of throttle in 1st or 2nd gear under 2500rpm be harmful to the engine?
Thanks, Ed
As long as your bike takes revs without lumpiness and chain snatching you're ok. My post was essentialy adressing the way that people tend to ride big singles, i.e 5:th gear and 25-30mph then giving it some stick to get that thumping feeling... :D
In my garage:
Honda VTR 1000F -00
Yamaha SRX-6 -86
Anders
Re: baghira
Postby rodge70 » Sun Nov 07, 2010 3:25 pm
taken from parts list,hr version shock absorber 412mm,spring 240mm,spring rate 80n/m,preload 16mm,and the full height version is 425mm,260mm,75n/m and28mm preload,and there seems to be 2 types of swingarm,baghira sm,baghira hr and the baghira sm hr and mastiff models,all have the non adj forks i think,i know mine is the baghira hr enduro but i also have a set of the longer sm forks which lift the front of the bike a little as when i have the sm wheels fitted the bike dips a bit at the front as it came with 18/21 wheels when new,hope this helps,cheers
rodge70
Re: baghira
Postby dazlandy » Sun Nov 07, 2010 3:44 pm
thanx rodge 70 , thats great info....where on earth did you find the parts lists ? ......ive trawled the net for manuals , data etc, and come up with bugger all !!....
cheers
daz
dazlandy
Users browsing this forum: No registered users and 68 guests
