125 SM revving problem
Postby Jamie » Tue Apr 05, 2011 12:55 pm
hi guys,
Could do with some help on this one.
Just stripped and replaced the piston in my sm125, rebuilt it got it running and the bike wont rev, i open the throttle and it just revs at constant speed no pick of which to speak.
I am wondering if its the ring aligment, loose rubber, or plug.
No oil leaks, no smoke from the exhaust, no water in the oil or vice versa.
This one is beating me, then i thought of all the knowledge on here.
Any help would be appreciated.
Jamie
Jamie
Re: 125 SM revving problem
Postby DAVID THOMPSON » Tue Apr 05, 2011 7:08 pm
check the intake rubber holding the carb on the head
and did the cable come unhooked from the slide in the carb while it was apart
Dave
also if new parts piston and rings dont expect it to rev high till its got some miles on it
Postby Jamie » Wed Apr 06, 2011 1:49 am
I will recheck all of them.
No the cable did not get disconnected, but worth a look.
Do i have to reset the valve clearances for replacement piston?
Will get back to you either way.
Thanks Dave, I knew i could rely on you or someone on here.
Jamie
Jamie
Postby DAVID THOMPSON » Wed Apr 06, 2011 8:57 am
also check to make sure choke is not still on or stuck open (fuel enrichment valve)on carb
if the head is off the bike then the valves need checked
but may be OK
Dave
never done it on the 125 yet and not looking forward to it
as it will probably cost toooo many $$$$$as it requires parts to do
Postby Jamie » Sat Apr 09, 2011 12:00 pm
Well dave, did as you suggeted, wasnt the choke or the carb slide.
The symptoms are, full throttle only produces what seems to be half throttle revs, for a while, then some smoke and cuts out, it seems to be that there is not enough fuel being drawn into the cylinder, and then it runs out of breath, which seems to be a ring problem, so stripped it, to find a lot of carbon on the valves, which wasnt there when i did the first striop down and the oil scraper ring was not too good.It broke whilst trying to re assemble
Will need a new one, not to bad £25 from Grahams.
My question is do i need to recheck the valve settings? on re assembly, and how do i do it.
Jamie
Jamie
Postby DAVID THOMPSON » Sat Apr 09, 2011 3:03 pm
not sure about the valves as i have never had a bike with the shims before
Postby Jamie » Sun Apr 24, 2011 3:12 pm
UPDATE, well Dave got it all back together and working,
its been running a week now and better than ever, just needed the rings to bed in.
Thanks for your assistance.
Jamie
Jamie
Postby DAVID THOMPSON » Sun Apr 24, 2011 3:47 pm
when mine was new it took about 3000 miles before it seemed like it was broke in
now at 20,000 miles it seems like its getting a bit tired
but still runs good for what i use it for running around town where the speed limit
is 45 mph or less
Dave
Return to 125 cc
Users browsing this forum: Bing [Bot] and 12 guests
