I'm trying to change the front brake pads on my 2005 Baggie for the first time since the bike rolled off the showroom floor (6 years, for the math-challenged). I knew the bolts would be stuck but good, but these haven't budged a millimeter. I've soaked both the heads and ends of the bolts overnight with penetrating fluid, but no luck. I even rounded off one of the small inner bolts (predictably), and when I drilled it and tried to remove it with the screw extractor, the screw extractor broke off in the bolt.
Anyway, I'm really worried about damaging a part that can't easily be replaced, so I haven't tried anything further. My first thought was heating the bolts with a propane torch, which works on things like the sprocket bolts, but I don't want to warp anything (or ruin the finish on the caliper, if I can help it).
Any brilliant ideas? Have I missed something horrible, like "you idiot, those are reverse-threaded screws!" I'm feeling as stuck as one of these bolts.
Thanks in advance for any insight/advice/magic tricks you want to share.
