TS 125 Top Speed
TS 125 Top Speed
Postby Rich_MZ » Sat Aug 20, 2011 7:18 am
Hi all ,
My TS125 (1986 Alpine) will only do about 55MPH flat out.
Its a well looked after bike , starts first time ( I have fitted an electronic reg to make things a lot lot better on the electrical front) , so before I start looking at the fuel / timing set up I would be interested to hear what others have had out of their 125's .
Also what front sprocket do people run with , mine has the standard 14T which to me seems a little "short" as the bike revs out very quickly in the first 3 gears.
1st is 0 - 10ish MPH , 2nd is 10-25ish MPH , 3rd is 25 - 42MPH and 4th is 42 - 55MPH .
Thanks in advance Rich
TS125 Alpine 1986.
Rich_MZ
Re: TS 125 Top Speed
Postby Skorpion » Tue Aug 23, 2011 9:55 am
Hi Rich,
I'm afraid I know nothing about the TS 125 but the manual states 60km/h,
Hope this helps.
Skorpion
Postby difflock » Tue Aug 23, 2011 2:04 pm
its a low power 2 stroke single.....
55mph isnt too bad in my opinion.....
thats the sort of speed I used to get from 125cc 4 strokes.....
there are ways to improve the top speed, but they may (or will) sacrifice the bottom end power....
a larger front sprocket is probably the easiest initially....
you could see about getting a 'tuned' exhaust (expansion chamber), for it....
it will move the power up the rev range a little, which may help......
clean/replace the air filter (if you havent already) can make a noticeable difference on any vehicle.....
difflock
Users browsing this forum: No registered users and 68 guests
