Check engine light,
Check engine light,
Postby Mach IV » Tue Oct 04, 2011 4:25 pm
tried the search but it ignored me so it looks pretty much useless.
Anyway,how do you reset it?
I disconnected the batt but that didn't work.
Mach IV
Re: Check engine light,
Postby boilermaker » Wed Oct 05, 2011 1:41 pm
Mach
As you have not told us why your engine light is on or what "search" you carried out then its difficult to help you. If you have carried out some sort of repair and the light is still on then be aware that it can take up to an hour of running before the light resets. The alternative is to reset it with one of the inexpensive fault code readers available on the market.
boilermaker
Postby iceman » Wed Oct 05, 2011 5:10 pm
John Lennon
iceman
Postby Mach IV » Wed Oct 05, 2011 6:52 pm
I forgot to plug the airbox in after changing the plugs,hence the CEL being tripped.
So,if the problem was resolved it should reset?
Mach IV
Postby Mach IV » Wed Oct 05, 2011 6:54 pm
The search was simply "check engine light" and all I got was the words were too common.
Funny,I would think that together they are not that common.
Mach IV
Postby iceman » Wed Oct 05, 2011 7:36 pm
I used what Boilermaker wrote: fault code readers
Now go put 200 miles on it and it should go out. :o
John Lennon
iceman
Postby boilermaker » Thu Oct 06, 2011 7:59 am
Mach
John (iceman) is correct it should go out within a couple of hundred miles. I have obtained a cheap fault code reader that I use to reset spurious fault indications it is the "Memoscan U480" unit and I obtained it via E-Bay for about £30. I cannot give you any more info as there are no manufacturers details either on the unit or in the hand book. Good luck.
boilermaker
Postby Mach IV » Sun Oct 09, 2011 9:12 am
I may ride it to Daytona this weekend for Biketoberfest.
I'm only 75 miles from there,trying to keep my rides short till I know
the bugs are out of it from sitting so long.
Mach IV
Return to 1000S
Users browsing this forum: No registered users and 126 guests
