ts 250 tank to ts 125
Postby landsurfer74 » Wed Feb 29, 2012 5:56 pm
Has anyone fitted a TS 250 tank to a TS125. I'm off on a long trip to norway in the summer and fancy a larger tank ... any body got any advice...
The Road Goes On Forever.
landsurfer74
Re: ts 250 tank to ts 125
Postby radiograf » Thu Mar 01, 2012 3:54 am
Check out the following website www.drive.drive-alive.co.uk/drivinginnorway for legal requirements, also the NAF (Norsk Automobile Forbund) which google can translate for you. The Norwegien police are very strict, with hefty on the spot fines for speeding, and you won't be allowed out of the country until you've paid! Also be aware that they have disguised speed traps, so you won't know until you've been pulled!
What front brake are you using, I would reccomend upgrading from the single leading shoe drum, as Norway is very steep! (Actually there is a lot of flat land in Norway, problem is it's all vertical!)
Another thing to watch out for is that traffic entering onto the road has right of way, except those roads marked with a yellow diamond.
A few useful translations:
bensin; petrol, gas,
bleifri; unleaded,
to takt ol; 2 stroke oil,
dekk; tyre
forgasser; carburettor,
cart, map
unshyld jeg er utlander, sprekke du engalsk?: Sorry I'm a tourist, do you speak english?
All the above aside do enjoy your trip
radiograf
Postby mhsilverw » Thu Mar 01, 2012 2:32 pm
landsurfer74 wrote:Has anyone fitted a TS 250 tank to a TS125. I'm off on a long trip to norway in the summer and fancy a larger tank ... any body got any advice...
Actually can I ask can a TS125/150 tank fit on a 250/1? Just a thought if my tank continues the 'shed' it's insides following yrs of standing...
M
mhsilverw
Postby radiograf » Fri Mar 02, 2012 1:56 am
The mountings are different betweent the 2 tanks, the ts150 mounts from below, as the ts250 bolts on at the rear. Not insermountable, just not a straigtforward swap. As for the rust inside a tank, I suggest that you re-petseal it.
radiograf
Postby landsurfer74 » Fri Mar 02, 2012 5:53 pm
There is no rust in my tank.
i know the mountings are different.
So has anyone fitted a TS250 tank to a TS125/150 ??????
Thank you radiograf; sensible advice ....
landsurfer74
Postby radiograf » Sat Mar 03, 2012 12:34 pm
Check out http://www.realclassic.co.uk. A guy there has taken an ETZ250 up to Nordkapp from the UK, its located under events then, ride and event reports, scroll down till you reach january 2011.
radiograf
Users browsing this forum: No registered users and 52 guests
