Shock Absorbers - Spring Preload Adjuster
Postby stuart-glos » Sun May 20, 2012 3:01 am
The collars that adjust the spring pre-load seem to be stuck solid.
I've had them soaking in oil for a week or so and tried easing them off under pressure and tapping with a hammer.
Any hints on how to free these off. The Haynes manual just says to "lift the off" but they're stuck solid.
thanks
stuart
stuart-glos
Re: Shock Absorbers - Spring Preload Adjuster
Postby radiograf » Sun May 20, 2012 10:18 am
Try warming them gently with a hot air gun.
radiograf
Postby mr_luke » Tue May 22, 2012 3:02 am
Do not be tempted to hammer on the sticky-outy bits, or apply any more force than you can with your hand!
I suppose you could potentially take the shock off, turn it upside down, find a bit of pipe or something which will sit over the bottom mount and bear onto the adjuster, and tap that downward. Wish I'd tried that on mine now..!
mr_luke
Users browsing this forum: No registered users and 95 guests
