Wiring on super 5 with electronic
Postby puckshole » Sun May 27, 2012 3:58 am
Trying to sort out the mess of the wiring on a Super 5 that has electronic ign fitted .
I have no wiring diagram & no spark at the plug . Im not sure if the wiring is correct on the coil , tried 3 coils so far .
Any idea what make of ign is fitted( see pics ) & any idea what wires go where inc the wires on the coils .
If poss does anyone have a diagram of the wiring which suits the electronic .
I know its a big ask but worth a try .
Many thanks .
Phil
Any idea what this little box is please
Phil : 1972 ES250/2 , 2000 Kanuni ETZ251 , 1987 ETZ 250 modified , & others
puckshole
Re: Wiring on super 5 with electronic
Postby therealche » Sun May 27, 2012 6:40 pm
Bugger, I had one of those on a Supa6 about 20 years ago. Could it be a newtronic? The black box is the "black box"that makes the electronic ignition work. The trigger on the dynamo is an opto-electronic unit. Mine got wiped out by the aluminium rotor and I went back to points. Have you carefully removed the wires from the black box and see whats written on it? Sorry I cant be any help
therealche
Postby DAVID THOMPSON » Sun May 27, 2012 9:57 pm
clean all the connections do not get any wires replaced in the wrong place
most of my electric problems over the last 10 years have been bad wires and connections.
Postby dwc » Thu Jun 07, 2012 11:28 am
Hi
Haven't posted for a while and have stalled in getting mt etz 250 running.
Looking at your photos I think I have the same system fitted. I to have no spark but electricity every where else.
Have you a remedy or are you replacing the unit.
Regards DWC
dwc
Postby puckshole » Thu Jun 07, 2012 2:53 pm
My non running MZs is at my mates bus depot & I havent been down to it lately to play ; so nothing as yet to report maybe this Saturday unless " she in the kitchen " wants something done .
otherwise I get " vision & no sound from her " again !!!! :evil:
puckshole
Postby radiograf » Thu Jun 07, 2012 4:17 pm
Had a simular system on a 6v jawa twin once, used to run fine when the battery was fully charged, however with all the lights on, when you turned the indicators on the engine would cut, only to fire up again as the light extinguished. This led to some interesting manouvers around traffic islands, as the power cut in and out. I would therefore suggest you fit a fully charged battery and try again, as these systems seem to need a lot of power to run. The other alternative would be to either fit the excellent power dynamo alternator/ electronic ignition, or revert back to points, which ever suits your wallet better!
radiograf
Postby puckshole » Sun Jun 10, 2012 12:47 am
many thanks for all the advice so far , still no sparks . Im using a brand new battery with plenty of power & using a trickle 6 volt charger on it all the time the ignition is on .
Still never mind , life with old Mzs is never easy
:idea:
Phil
puckshole
Postby DAVID THOMPSON » Sun Jun 10, 2012 10:45 am
try just running the coil and points part of the system from a good battery...
something in other areas of the system may be dragging the voltage down
had a harley hummer in the late 1950's ran the thing from a 6 volt car battery.
and charged it at night
the hummer was a very bad copy of a DKW rt125 and i mean a real bad copy
Postby dwc » Sat Nov 10, 2012 9:49 am
Dear All,
I have been revisiting my previous posts.
I still have problems with the ETZ 250. To be precise no spark.
I was tinkering again yesterday and wondered whether it might be the carbon brushes which were at fault, they appear quite worn and probably require replacing.
Also while looking at the pictures posted below, which is the same system as mine, what does the black box do and what would one replace it with if I returned to a point or a new electronic system?
Better still somebody make me a sensible offer so I can end the frustration!!!!
Regards DWC
dwc
Users browsing this forum: Google [Bot] and 7 guests
