10,000km service on '98 Skorpion
Postby Ratbag » Thu Jun 07, 2012 3:54 pm
yup it's time for the 10,000kms service next week. new oil, plugs, filters, brake and clutch fluids, chain and sprockets, coolant. Is there anything else that should be done?
Ratbag
Re: 10,000km service on '98 Skorpion
Postby basser23 » Sat Jun 09, 2012 7:44 am
Think I'd clean the carbs too.....
basser23
Postby DAVID THOMPSON » Sat Jun 09, 2012 9:59 am
carb and gas tank clean out a good idea any time you have a chance....
beats having some one come get you when your stranded from crud in the tank and float bowl ..
my rt125 is fair to easy to do the traveller and saxon tour are a pain
and best done just out side in the drive way...
GOOD TIME to replace the fuel shutoff o-ring where it seals to the tank with a good one made with Viton
fuel running down your pants leg on the road is no fun
Postby Ratbag » Sat Jun 09, 2012 9:04 pm
where the hell can I get my hands on the fuel oring with Viton in OZ? I have a fuel leak from the hose connection outlet now..but its not leaking all the time..aaaaagghhhh
thanks for your help with the advice on the carbies too, I have yet to delve inside them....
Ratbag
Postby DAVID THOMPSON » Sat Jun 09, 2012 10:48 pm
i am looking for a supplier
got mine in a assortment at an auto parts place
over 8usd for the pack
but only 1 seal the correct size in the pack
screwed again in the pocket book
Postby Ratbag » Sun Jun 10, 2012 2:24 am
I'll sort that out then as soon as possible. Ive just replaced the fuel tap on my Sherco trials bike, the tap looks very close to the MZ!
Ratbag
Postby basser23 » Sun Jun 10, 2012 10:02 am
Acerbis makes a universal fuel petcock that fits well ..reserve is a bit low on capacity though..
basser23
Postby Ratbag » Tue Jun 12, 2012 3:29 am
Bike back in garage and its alot quieter and I dunno but it seems more powerful and easier to ride!
Thanks for all your advice.
Ratbag
Postby DAVID THOMPSON » Tue Jun 12, 2012 5:27 pm
got some mz parts a few months back..
in looking at things the gas tank cap rubber seals i ordered
HAVE CHANGED
they have a turned down lip edge
the ones i ordered were for rt125
and fit my rt125 the saxon tour and the traveller
hope it keeps the rain out
also looking at the local parts place and stabil has a type treatment
for gasoline with ethanol in it may help with the water
Postby buckwheat5679 » Sun Aug 05, 2012 12:46 am
Make sure you check the valve adjustment. I check mine at 9000mi. and the intakes had zero clearance.
2002 Traveller
2007 GasGas ec 300
1963 Honda 55
buckwheat5679
Obsessive Skorpion servivce items
Postby jimc » Mon Aug 06, 2012 6:10 pm
My '96 Skorpoin Sport just got a major service, in addition to all the excellent suggestions above,
I serviced the rear mono shock pivots and front forks.
Front:
-fork oil change , you'd be amazed at the mud !
-steering head bearing re-grease
Rear:
-caught the spherical bearing at the bottom of the shock just in time , flush with solvent and re pack with Moly Disulpide
(CV JOINT) grease.
- re grease all needle roller bearings swing arm and shock pivot All should be possible without removing the seals, altho next time around I'll probably do those. The MZ assembly people are obviously very stingy with grease, hardly any in there.
There's a good article for this work:
http://www.totalaptitude.com/skorpion/Page%201.htm
I'd like to hear what antifreeze is OK on these bikes, I've been running ordinary Prestone, but I wonder about all the
concern over phosphates etc.(?)
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Users browsing this forum: No registered users and 78 guests
