ETZ 251 1992 Battery type
Postby tonyc » Mon Oct 29, 2012 5:27 am
Can someone tell me what the correct battery type is for a 1992 ETZ 251 please?
tonyc
Re: ETZ 251 1992 Battery type
Postby therealche » Mon Oct 29, 2012 4:31 pm
YB5L-B is the bog standard battery. there sill be gel-fill and other ones available I'm sure, but if its a bike in regular use I've always found a standard lead acid will do the job
therealche
Postby radiograf » Mon Oct 29, 2012 4:46 pm
A ytx12bs will fit in the battery tray, if you don't mind loosing the strap and tool tray. You need to lengthen the earth cable as the terminals are the opposite way round.
radiograf
Postby tonyc » Thu Nov 01, 2012 8:22 am
The shop only has CB5L-B Will that fit? The shopkeeper is saying that the C denotes the manufacturer. Is that correct?
tonyc
Postby Norman Wade » Thu Nov 01, 2012 8:53 am
Norman Wade
Postby radiograf » Thu Nov 01, 2012 1:55 pm
They are the same battery, different manufacturers use slightly different codes to avoid copyright issues.
radiograf
Users browsing this forum: Bing [Bot] and 7 guests
