malachi wrote:Mine blew the paint over the winter too, just random bubbles under the paint. aprilia rsv's have a plastic tanks made byacerbis and suffer with the same problem. it the ethanol that is being put in petrol now.the ethanol ishydroscopic and draws moisture through the plactic, If you burn it off on a ride out it doesn't have chance to affect the tank but if it sits then it does. It's highly corrosive as well if it gets on parts of your bike. I have been told by a mate with a aprilia that if you dry the tank out and leave it somewere warm the tank will go back to normal if its not to bad.
