Front brake gone bad On Baggie
Postby harold » Sun Apr 21, 2013 12:27 pm
My 2001 Baggie only has around 3,500 miles on it, and the front brake has started getting mushy and letting the level come to the handle bar. It has been sitting a few months, and today it was much worse than before, to the extent it wasn't doing hardly anything until pumped a few times, and then it was just real weak. One of the last times I rode it, I did a quick bleed by pumping it up and opening the caliper nipple. I expected to see some air, but none was apparent. It didn't change.
So today I took off the Master Cylinder lid, and fluid was up to the top. It was a little brown, but you can still see through it good. When I squeeze the lever though, it shoots a squirt up through the bottom hole that is closest to the center. Opening the bleeder nipple lets fluid drip out, but when squeezing the lever it only shoots out in a weak stream, and I expected it to give strong squirt.
I am pretty sure it is the master cylinder that will need to be disassembled and cleaned, but has anyone else had this problem?
harold
Re: Front brake gone bad On Baggie
Postby DAVID THOMPSON » Sun Apr 21, 2013 5:47 pm
sounds like it all needs a good flush and new fluid.
but get a grip on your billfold if you need to replace any of it
Postby amahoser » Mon Apr 22, 2013 12:25 pm
The fluid shooting up with the cover off is normal. Sounds like you just need a good brake bleed. To do it yourself, a vacuum pump like a Mity Vac makes it easy.
Jose Soriano
2003 MZ Baghira
2008 Aprilia Shiver
2008 Harley Nightster
2000 Kawasaki Concours
2002 Honda XR400R
2008 Genuine Rattler 110
1974 Vespa Rally 200
1963 Vespa GL 150
amahoser
Postby harold » Tue Apr 23, 2013 5:28 am
Thanks for the replies. I am not sure that bleeding is going to help, as I have never seen any air come out so far. It is just like the master cylinder has suddenly only half of its power or volume of fluid moving. The fresh fluid flush I did made no difference. I will try again.
harold
Postby DAVID THOMPSON » Tue Apr 23, 2013 10:42 am
it needs a serious clean up new type brake fluid loves to suck up water
and be careful it eats plastic
Postby duncmac » Tue Apr 23, 2013 3:39 pm
And it eats paint, dont get it anywhere near the body work, put rags everywhere. Even if you're being super carefull
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
