Baghira oil change
Baghira oil change
Postby duncmac » Mon May 20, 2013 9:24 am
Did the oil yesterday.
There was no washer or oring on the sump plug. What size oring goes there?
Wasnt leaking, bit hard to undo though, used a copper washer instead.
Same for the frame/course filter. No washers, done up extra tight. What should be here, metal washer or rubber washer?? Any idea on sizes?
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Re: Baghira oil change
Postby den » Mon May 20, 2013 2:41 pm
hi mate , i drained the frame oil via the banjo at the bottom of the frame tube,,banjos always need a copper washer,,top and bottom,,the sum plug bolt will need one as well as this helps it to seal and stops it from seizing,
den
Postby duncmac » Tue May 21, 2013 1:36 am
Hmm none present when I pulled the frame tube pipe.
Just done up extra tight.
Does anyone know the size?
Otherwise I'll ring up grahams.
duncmac
Postby den » Tue May 21, 2013 4:22 am
oil line for baggy
den
Postby duncmac » Tue May 21, 2013 5:45 am
Cheers Den
Cant find any 16 x 12 washers so have emailed grahams spares to see if they can advise or provide.
duncmac
Postby den » Tue May 21, 2013 11:40 am
duncmac wrote:Cheers Den
most oil line banjos are of a standard ,just go to any car motor factors and ask for copper washers, cheap as chips, i think i remember seeing some in halfords,,sump plug washer 16 x 12
den
Postby duncmac » Tue May 21, 2013 1:48 pm
Cheers, but cant see any 16x12's plenty of 16x20's though
duncmac
