Presumably this is the same as a Yamaha part ....? Or is life going to get difficult suddenly ..............?
And who's most likely to have it if it's a MuZ part?
Ta in advance.
aah5 wrote:Also thought about putting in a rubber bushing at the lower end but I had materials to hand for the bronze bush.
arry_b wrote:Apologies for the resurrection of a long dead thread, but I've found a replacement spherical bearing that's easily obtained and sensibly priced.
It's a:
GE12PB Steel / Phosphor Bronze Spherical Plain Bearing 12x26x16x12mm.
I got mine from Simply Bearings (UK), cost is £22 delivered.
Unlike the standard bearing it's got a central grease channel, so I've fitted a grease nipple to the crescent. Fitting the bearing was simple enough with a suitable sized drift.
Don't be tempted to fit an IKO GE12G. They're cheaper, but don't have a wide enough central support.
'arry.
Users browsing this forum: Google [Bot] and 17 guests
