Need front brake master cylinder and mirrors for my baggy
Postby Honeybadger » Sun Jun 09, 2013 9:21 pm
Howdy folks, my grimeca front M/C has started leaking, and I need to replace it, along with my mirrors. What cheap options are there for mirrors, and what are my options (not cheap, when it comes to brakes I want to spend money) for a new master cylinder? Or, are there rebuild kits for them? It still performs fine, but it's seeping around the actuation pin.
Honeybadger
Re: Need front brake master cylinder and mirrors for my bagg
Postby duncmac » Mon Jun 10, 2013 1:48 am
rebuild kit will have seals to fix this, I dont know what other makes used the same set up (ie easier to search for spares)
Think I've seen some talk on here about upgrades for the perch/master cylinder.
Search bill J's posts.
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby DAVID THOMPSON » Mon Jun 10, 2013 8:33 am
go somewhere that a lot of bmw bikes show up ...
and look at what is installed on models from 1980 to 1990
some of the r65 or r80 stuff may fit
Ducati maybe i do not know because there almost as rare as my mz's where i live
the front unit on a kaw klr 650 looks close
in fact it uses the same brake pads as an 125 sx on the front left
below links can help you find a brembo part number
http://www.yoyodyneti.com/category.aspx?categoryID=2986
http://www.yoyodyneti.com/Category.aspx?CategoryID=3006
this one may work but banjo bolt with switch on hose required to get the brake lamp switch
http://www.yoyodyneti.com/ProductInfo.a ... 10.4620.95
there are ones with switch but require that ugly remote fluid tank
10.4776.83 is rear master cylinder on my rt125
its rear caliper looks same as klr650 after 2010 and some kymco scooters bet and win 150/250
Postby Honeybadger » Mon Jun 10, 2013 12:38 pm
do you know what the banjo size/bore size is on our bikes?
Honeybadger
Postby DAVID THOMPSON » Mon Jun 10, 2013 4:47 pm
looking at my notes from past work on my rt125 bike aprilia number on parts bag is 8124479
KTM BRAKE LIGHT SWITCH REAR 98
50311051144
but double check
all this stuff should be available at a good spares dealer in the uk
Users browsing this forum: Google [Bot] and 126 guests
