Dead MZ 300
Dead MZ 300
Postby Deedum9 » Mon Aug 12, 2013 3:23 am
Hi all
Newbie here and just purchased what was a running 1996 MZ300.
Collected it, checked all oils, tyres etc, sorted insurance and set off for a spin on the trusty old 2stroke.
Managed about a mile or so changed up into 3rd and then hesitation, smoke, lack of revs and wouldn't pull.
I pulled over it was idling badly barely ticking over lots of smoke and then stopped. I couldn't start it again, seems to have compression though.
Now sat in the shed, fuel seems ok and running freely, any thoughts or ideas please :cry:
Thanks in anticipation
Steve
I like my Hayabusa, cus it just works :(
but I like a challenge :)
Deedum9
Re: Dead MZ 300
Postby arry_b » Fri Aug 16, 2013 12:06 pm
Choke bung not sealing properly. The over rich mixture kills the plug.
I bought a 1994 301 with the same problem. £5 spent on a new bung and a plug and it took me touring in France.
arry_b
Re: Dead MZ 300
Postby Deedum9 » Sat Aug 17, 2013 1:20 pm
choke bung ? I really am new to this :?
Deedum9
Re: Dead MZ 300
Postby therealche » Sat Aug 17, 2013 4:29 pm
So part 16 ( a rubber washer) has a habit of dropping off part 15 ( brass......thing!) and blocking the starter circuit in the carb. So the engine is runs very rich
therealche
Re: Dead MZ 300
Postby Deedum9 » Sun Aug 18, 2013 2:11 am
wow, thank you ok, i'll check that too :-D
Deedum9
Re: Dead MZ 300
Postby Deedum9 » Thu Aug 22, 2013 3:21 pm
She lives !!! :-D
Had some time tonight and tried to find the points and check them out.
Removed the cover and there's a group of wires running to the front and one thinner wire from the same loom running to the back,connects into a tiny screw ?
The wire was burnt out/snapped, anyway fixed the wire and started her up , all good.
So question is, what was this wire please ?
Deedum9
Re: Dead MZ 300
Postby DAVID THOMPSON » Thu Aug 22, 2013 4:24 pm
what was the color of the wire
if brown that is usually a ground
a good quality picture would be great so others would know where to look
Re: Dead MZ 300
Postby Deedum9 » Fri Aug 23, 2013 1:19 am
Yes sorry , I will take a picture, but it was quite thin and blue or green
Deedum9
Re: Dead MZ 300
Postby arry_b » Fri Aug 23, 2013 4:48 am
That's the wire to neutral switch.
I suspect your red box has started working again. This happy state of affairs is only temporary, unfortunately. It will break down again.
arry_b
Re: Dead MZ 300
Postby therealche » Fri Aug 23, 2013 3:47 pm
arry_b wrote: This happy state of affairs is only temporary, unfortunately. It will break down again.
:lol: :lol: :lol: so true!
therealche
Re: Dead MZ 300
Postby Deedum9 » Sat Aug 24, 2013 4:36 am
not sure what it is or what it's called , but it's the small wire by the chain
Deedum9
Re: Dead MZ 300
Postby therealche » Sat Aug 24, 2013 6:07 am
Yes that's the neutral switch. Unlike modern complicated bikes, all it does is make the neutral light work. Now send us a picture of the generator ignition set up!
therealche
Re: Dead MZ 300
Postby Deedum9 » Sat Aug 24, 2013 1:01 pm
Is that the other bit on the other side :?
Deedum9
Re: Dead MZ 300
Postby therealche » Sat Aug 24, 2013 2:43 pm
Its the other bit on that side which may or may not look like this
therealche
Re: Dead MZ 300
Postby Deedum9 » Sun Aug 25, 2013 2:14 am
right, ok, will do, it looks clean but similar....yes :-D
Deedum9
Users browsing this forum: Google [Bot] and 10 guests
