Sidecar:- ETZ250 to 251
Postby Tony the Skin » Sat Aug 24, 2013 3:26 am
A mate of mine has an ETZ250 with a chair on. He wants to remove it and put it on a 1994 ETZ251. The hope was that this would be an easy move. Are the frames identical ?. Will the connection points be the same ? The chair is a fairly lightweight Squire.
Tony the Skin
Re: Sidecar:- ETZ250 to 251
Postby therealche » Sat Aug 24, 2013 6:15 am
Same frame so should bolt straight on. Make sure everything is good and tight but don't crush the box frame, I have seen one torn through after a few years of spirited riding
therealche
Postby Tony the Skin » Sat Aug 24, 2013 8:17 am
Thanks for the reply. On the 250 the front connection from the sidecar was joined to the bike at the bottom of the Yoke using a bracket that is bolted through the Yoke. It seems to be higher on the 251 than on the 250. Hope to have another look at it on Tuesday.
Tony the Skin
Users browsing this forum: No registered users and 64 guests
