ronseagoon wrote:I have in intermittent fault on the ignition switch on my Trophy Sport, the engine will cut out and the light goes out, with a bit of fiddling I can get it to work again, I have sprayed it with WD40 but this doesn't seem to help, is their a cure? or will I need to replace it?.
therealche wrote:No relays on a Trophy Sport... and any dialectric lube is likely to have disappeared over the last 40 years!
therealche wrote:I have had some success by removing the switch and soaking it in WD40 ( I buy it by the gallon) and working the switch back and forth. Then wash it out with switch cleaner.
To take the switch apart you need to drill out the hollow rivets that hold it together. These can be replaced by nuts and bolts when you re-assemble the switch. Never done it myself and if you lose any of the little bits inside you will need to buy a new one anyway!
therealche wrote:That's good.... but start saving up for a new one!
therealche wrote:When I had a succession of Supa5s ... all used abused, stored outside in all weathers, I had a couple of switches pack up, and have come across a few when working on mates bikes. Get a new one and it will last you another 40 years... probably a lot more as MZs now live in garages!
Users browsing this forum: Blurredman and 19 guests
