DAVID THOMPSON wrote:a word on removing the tank on a mz 660 there is a bracket on the rear of the mz tank
DO NOT TRY TO REMOVE THE BRACKET FROM THE TANK
take the bracket loose from the bike
the taps in the tank will turn loose and then you have a real mess
and new tanks are ????
edfmaniac wrote:You may have to work it but it comes out. Same goes for putting it back in. You may have to squeeze the mount together and cuss at it to get it to fit in between the ears on the frame, but it will go back in.
