by DAVID THOMPSON » Thu Mar 27, 2014 4:59 pm
if there are brushes on the alternator clean the contact rings and check the brushes
- Moderator
by Cerberus73 » Thu Mar 27, 2014 5:22 pm
yeah they are brushes, gonna do that when i fit the solid state regulator.
Cerberus73
by therealche » Thu Mar 27, 2014 6:53 pm
Cerberus73 wrote:I had a old kawasaki KH125 that had similar issues with indicators, but after fitting a good rectifier/regulator and a new flasher can it sorted its issues out.
Ah thats it! A lot of Japanese bikes combine the regulator and regulator in one unit so if one goes you have to replace the both of them. MZ have the common sense to have the two bits separate! The MZ rectifier is very very reliable so I would leave it where it is
therealche
- Moderator
by Andy_C » Fri Mar 28, 2014 3:20 pm
I recenty bought a well used / rough ETZ 301.
I went through the electrics from top to toe - many of the push in connectors had become loose or made poor contact.
I cut the old terminals off and replaced them as necessary and cleaned up all the terminals best I could.
Now seems to charge OK - it also fixed an indicator problem that the bike had when I bought it.
So definately recomemned going over the wiring and use a meter to check continuity.
Andy_C
