I'd recognise those red rear springs anywhere, this is my old girl
I'm Dave, the guy who trailed it up to you all the way from the northeast
Sorry to hear you're having trouble with her, I hope you manage to get it sorted in good time. The 'Clack' noise that you're hearing is pre-ignition on the overrun, quite common on the 2-stroke machines. They can sound horrendous popping and banging on the overrun, the usual solution is to have virtually zero idle so there's no fuel getting into the chamber, the only downside of this is the plug will oil up quite quickly.
I'm surprised you're having trouble with the bing carb though, they're very reliable, the one on my 301 is some 40k miles old and has only ever needed a new needle and jet housing.
I can't remember if it's possible with the Bing 84, but have you got the carb slide in the wrong way round? this has happened to me before, obviously the throttle is then stuck about 25% open!!!
Other things to check are the gaskets on the Stub-inlet to the engine and Carb. There's a round one between the Stub and the carb, check the carb is pushed right the way home then tighten the clamp. Also make sure the one between the Stub and the Cylinder barrel is positioned correctly, you can get it 4 different ways round and only one of them is correct! Sometimes it drops down and you bolt right through mid-air without noticing!
Finally, I mentioned at the time but it's worth saying again, the Electronic ignition is of my own design and although I'm confident in my abilities, I can't guarantee it. Go back to points and see how that goes.
I look forward to seeing how you get on.
Dave.
P.s. I've lost your address and still have the old spare BVF carb to send to you along with a couple of other bits. I haven't found the side panel transfers yet though.
