gear lever availibility
Re: gear lever availibility
Postby handsomejackuk » Wed Jun 11, 2014 3:33 pm
handsomejackuk
Postby Guido » Wed Jun 11, 2014 4:08 pm
Item number:-
201106496631
Sorry wasn't Ebay De , was ebay fr but item number should work from uk as it's available to European Union.
Regards Allan
Guido
Postby Guido » Wed Jun 11, 2014 4:14 pm
That's actually the third different style of lever I have seen for a Mastiff!!
Allan
Guido
Postby handsomejackuk » Wed Jun 11, 2014 4:37 pm
think its the same item... looks a bit shabby... i hang on to find a better one if i do !!!!!
have made one for now, and it seems to be ok... tried it out briefly tonite..
handsomejackuk
Postby breakwellmz » Fri Jun 13, 2014 1:24 am
Oh to be back in the old workshop-Take the splined bit and join it to the lever at the length i wanted,easy!
You`re using a lever only without a linkage are you,how are you getting on with it?
I do wonder if we`re missing something here-Why is a linkage there if it isn`t needed?
What do other similar Yamaha engines use?
Postby den » Fri Jun 13, 2014 6:52 am
would you like to commission me to make you one , you can have custom shape, measurements,what ever,,how much would you like to pay,, :smt006
den
Postby DAVID THOMPSON » Fri Jun 13, 2014 10:16 am
standard pattern by law most areas is 1 down then 1 n 2 3 4 5 up
a straight lever results in 1 up then 1 n 2 3 4 5 down or a reverse pattern also called GP pattern
as rear sets reverse the shift
this motor because of the way its shift is made requires the reversing lever to get it to shift the way the law requires
for street use...
i made some good money when i was a kid making english bike conversions to get the shift and brake on the
proper side for usa street use the racers left them the english way
Postby den » Fri Jun 13, 2014 11:58 am
whooo , had an idea,, lets go tiptronic,,do away with the lever altogether and have an up down button on the handlebar,gear position indicator aswell,, its not a new idea , there are kits already available,,
anyways,, the gear lever from a YAMAHA FJ1200 looks close,
den
Postby handsomejackuk » Fri Jun 13, 2014 1:35 pm
den wrote:would you like to commission me to make you one , you can have custom shape, measurements,what ever,,how much would you like to pay,, :smt006
hi Den,
fiding neutral a bit hard to find, the lever i got is a bit of a home made affair at moment... but it will do until i find summut better...
handsomejackuk
Postby Glidd » Fri Jun 13, 2014 4:32 pm
BA Bikes have a MZ 660 Baghira & Mastiff Rear brake lever on UK eBay for £38.50 or offer.
2003 Baghira SM
1995 ZZR1100
Redditch
UK
Glidd
Postby handsomejackuk » Fri Jun 13, 2014 5:09 pm
dont see a gear lever on there Glidd ?
are you sure ?
can you posst link....
Al...
handsomejackuk
Postby breakwellmz » Sat Jun 14, 2014 6:26 am
DAVID THOMPSON wrote:standard pattern by law most areas is 1 down then 1 n 2 3 4 5 up
for street use...
Hi.
Am i being thick?
I`ve looked at this linkage again this morning.
If the lever is pushed up(Rotated clockwise),the splined shaft also rotates clockwise.Only if a lever was put on the splined shaft facing`backwards`would the shift pattern be reversed,wouldn`t it?
Postby handsomejackuk » Sat Jun 14, 2014 7:02 am
standard shift... if you put the lever on the splined shaft it is as normal same as any other XT600...
handsomejackuk
Postby breakwellmz » Sat Jun 14, 2014 7:27 am
Thanks for that!
Not familiar with XT singles other than the one in mine.Presumably`ours`has a larger lump on the LH side compared to earlier XTs,otherwise you could just fit one of these-
http://www.ebay.co.uk/itm/310486519424? ... EBIDX%3AIT
Is this any help?-
http://www.wemoto.com/bikes/Yamaha/XT_6 ... ear_Lever/
Cheers
Postby DAVID THOMPSON » Sat Jun 14, 2014 12:12 pm
my traveller was modified so much by past owners it is probably not like any in the uk
?? and none to compare it with here..
Users browsing this forum: No registered users and 103 guests
