baghira fairing bar removal.
Postby eire1400 » Mon Jul 14, 2014 12:13 pm
Hello all. I have seen a few baghira 660's with no 'metal fairing bars' fitted.
How do ye people keep you side panels on? where is the headlight and clocks mounted?
Anyone done this and got some close up pics?
eire1400
Re: baghira fairing bar removal.
Postby rodge70 » Mon Aug 11, 2014 9:14 am
here is my baghira with only the bottom bit of the bars retained to hold the tank panels on,have fitted a couple of bright led's in the ends to tidy them up a bit.
i tapped an m5 thread in top yoke clamp bolts and fixed the indicators there after tightening bolts up and headlight fits with the straps supplied,though i had to split a length of 40mm waste pipe to slip over fork tubes to increase dia to make the headlight a firm fit.trailtech hangs from a bent bit of metal fitted to back of headlight unit.
rodge70
Postby eire1400 » Wed Aug 13, 2014 2:36 am
Nice work, exactly what I was looking for. food for thought thanks
eire1400
Postby Guido » Wed Aug 13, 2014 6:20 am
Hi Rodge
Which bar clamps are you using?
Allan
Guido
Postby rodge70 » Sat Aug 16, 2014 10:38 am
hi,got them through work,hi-level catalouge i think,not the dearest around but seem to do the job fine and came with sleeves to fit standard dia bars and a doddle to fit
rodge70
