Traveller headlight shaking
Postby billr » Fri Sep 19, 2014 5:52 pm
I've always noticed a bit of a shake in the headlight. Bulb failed a few months back. It was from one of the base wires broken through (probably from the shaking).
Had the housing off for a couple of things and notice that the reflector is loose in the housing. Aim is OK, just able to move the reflector around.
Seems there would be some springs on the adjustment screws or something.
I don't see any way to separate the lens from the housing to get in there and check what to do.
Has anyone else noticed this or had their lens off the housing?
Thanks for any info.
Bill R
Nashville, TN
billr
Re: Traveller headlight shaking
Postby DAVID THOMPSON » Fri Sep 19, 2014 7:56 pm
i have not rode mine much in the dark ...but did notice something needed to be done about the headlamp...
when i did ...lots of deer here they feed in the side yard close to where i park my cars and bikes
i have stood at the window and counted in excess of 20 one morning
and have stopped riding at night unless i go very slow about a mile to the market 20mph or less
we have very low posted speeds here and the deer are one of the reasons ...
Postby hb7 » Wed Oct 08, 2014 11:20 am
the reflector is off the adjuster screws.....
hb7
Postby billr » Fri Oct 10, 2014 8:20 pm
hb7 wrote:the reflector is off the adjuster screws.....
I thought that, also. I can move the reflector with either screw.
It holds aim fine. Just odd watching the shake at idle and wondering what the cars in front see.
As long as it still works and doesn't eat bulbs often, I'm not ready to put it in the oven to take off the lens just to find out what is going on.
Bill R.
billr
Users browsing this forum: Bing [Bot] and 14 guests
