660 baghira regulator
Postby rsanthill » Tue Dec 30, 2014 11:08 am
hi there i bought a new battery as the old one was dead. after 4 rides the battery was down on voltage. with a meter i saw that it is not charging and i am thinking that it is the regulator. where it is so i can take it off and buy a new one. thanks for your help.
rsanthill
Re: 660 baghira regulator
Postby den » Tue Dec 30, 2014 3:25 pm
unsure wether its the regulator thats the problem,regulator side of the circuit just give you a set voltage coming from the alternator,(regulates voltage) if its dodgy you usually see the main beam lights rise and fall with the rpms.its probably the rectifier side,, this converts ac voltage from the alternator to a dc current for charging,most rectifiers from a bike with the same size engine or bigger will work ok,just match the pins up,first of all i would clean all the connections and ask here if the diode in the loom has anything to do with this fault , ;-) ,
you could also read this,, very helpfull..............viewtopic.php?f=3&t=5117
den
Postby DAVID THOMPSON » Tue Dec 30, 2014 4:03 pm
check the plug in to the harness it went out on my rt125 at about six years it was fried like toast
Postby rsanthill » Thu Jan 01, 2015 4:40 am
Thanks guys as soon I have time I will work on it and let you know. Thanks again
rsanthill
Users browsing this forum: No registered users and 48 guests
