Changing 125SM Monoshock
Postby jbthumper » Sat Feb 12, 2005 3:53 am
Guys,i was wondering what u guys think if i change my monoshock to a ktm200exc monoshock.....is it doable??will it work nicely??
Well...it's just an idea....
Waiting to hear from u guys!!!
Cheers,Din.
jbthumper
Postby builtone » Mon Jun 06, 2005 8:35 pm
Aso curious about this mod.
builtone
Re: Changing 125SM Monoshock
Postby mxsteven » Mon Jun 06, 2005 11:45 pm
hehe jbthumper started his fantasy...... well i hope to put XR ohlins adj shock and XR engine into my SX hehehe... my 2cents of fantasy..
jbthumper wrote:Guys,i was wondering what u guys think if i change my monoshock to a ktm200exc monoshock.....is it doable??will it work nicely??
Cheers,Din.
Where u go, it's up to u,
Think b4 u do, Ride safe.
MXsteven
mxsteven
Postby Drew » Thu Feb 02, 2006 11:58 pm
FWIW, Wilbers makes a shock for this bike. That's probably your best bet (unless the mod you listed was for financial reasons, e.g. you just happened to have one lying around).
Relax. You'll live longer.
Drew
Postby phlat65 » Fri Feb 03, 2006 10:35 pm
well, doesn't the 200 use a PDS shock with no linkage? it may get a little funny running a position sensitive shock with a linkage system. you may find it not progressive, or the extreme ends of the stroke will be to far different. I would stay with a shock from a linkage system.
Postby jbthumper » Sat Feb 04, 2006 1:15 am
i found out a couple of months back that the 200exc shock is a linkage system...the thing is,the 125s' are not linkage type. So they are definitely a no go.
then i saw this 125SX(KTM) shock which does not use linkage. Same as the 125's system(position wise). However,the travel length is too long i think(haven't check though) in which i think will effect the bike's balance.
the stock ones are fine(for it's purpose). It's just an idea that i had :-)
Cheers.
p/s: where i live,it's easier to get KTM parts than any performance parts that are specificly for MZ.
:smt033
jbthumper
Users browsing this forum: Bing [Bot] and 40 guests
