Tachometer/revcounter
Postby vicar » Thu May 28, 2015 2:58 pm
my revcounter has gone mad. A quick blip of the throttle results in a reading of 10,000 rpm. Whatever damps the needle has stopped damping.Can I take it apart and fix it myself every or do I need to buy an other one. I have the round type fitted to my bike...
vicar
Re: Tachometer/revcounter
Postby DAVID THOMPSON » Thu May 28, 2015 4:04 pm
most of the new units now are electrical and the weather takes a toll on them
a good clean up may help ..and it may have a capacitor that needs replaced
some of them were of low quality to start with
some days the one on my 2002 rt125 goes nuts other days it works ok
put a volt meter on the battery plus and minus and see if the voltage is stable
my tack was way off once and the voltage regulator was going bad
or maybe the battery /loose wires also
Postby therealche » Thu May 28, 2015 5:24 pm
Well if it's already broken , you have nothing to lose opening it up. I would not try to pry the rim off, it is difficult to do, you risk cracking the glass and it is very difficult to reseal it after it. What I have done before is carefully cut the case in half horizontally ( I used a dremel) It is possible that the balance spring has become disconnected and you MIGHT be able to re-attach it. To put it back together I cut a strip of metal about 20mm wide, glued it inside one half of the casing using araldite so around 10mm stuck up the edge, let it set then glued the other half of the case onto the strip.
Or just bin in and buy a new one, but I love trying to mend the unmendable!
therealche
Postby vicar » Thu May 28, 2015 6:14 pm
Thanks ,I will hack it to bits it's the old cable driven round type but if anyone has one in the UK for sale pm me ....thanks
vicar
Postby MZCountryRider » Fri May 29, 2015 8:23 am
Here is some information on removing and reinstalling the trim ring:
http://www.thisoldtractor.com/moto_guzzi_loopframe_gauge_trim_ring_removal_and_installation.html
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby 95SaxonTour » Sun May 31, 2015 2:17 am
The MZ Miami (mzmiami) store on the bay has the speedo tach combo for $60 shipped. Pretty reasonable, imho.
Always have had a good experience dealing with the folks there. Their store in Miami is breathtaking to an MZ aficionado.
Ryan
95SaxonTour
Postby vicar » Sun May 31, 2015 12:27 pm
Thanks for the reply's if anyone has a round cable driven rev counter they would sell pm me...Thanks
vicar
Users browsing this forum: No registered users and 58 guests
