Radiator/coolant hose availability
Postby dunekahn » Mon Aug 10, 2015 1:45 pm
Hi all, I've not been on here in years, I've neglected my 2002 Baghira Street Moto.
I've gotten her roadworthy again, but have noticed my coolant hoses are looking pretty raunchy. I replaced the small hose that joins the radiators at the top with some reinforced line, due to the original cracking and leaking.
Does anyone know if the hoses used on the Baghira are common to any other bikes that use this 660 Yamaha thumper? I've been looking- I've found a bunch of other useful info, but not for coolant hose replacement.
She sat so long I had to disassemble and clean the carbs out before she'd run right and not pee gasoline on the floor, lol!
Thanks for any help you can provide.
D.
2002 MZ Baghira SM (yellow)
1964 Harley Davidson pan/shovel (basket case)
1970 VW Bug (General Vee)
dunekahn
Re: Radiator/coolant hose availability
Postby ericetz301 » Tue Aug 11, 2015 4:26 am
hi there,
check out Yamaha XT660 parts for direct replacements, although I used a section of 19mm ID silicone hose from ebay, to replace a section of hose running from the top of the water pump to the engine block, as it was out of stock/no longer available from my local MZ dealer here in the UK.
cheers Eric.
ericetz301
Postby dunekahn » Thu Aug 13, 2015 8:44 am
Thank you Eric, I'll check into that.
D.
dunekahn
Postby DAVID THOMPSON » Fri Aug 14, 2015 6:59 pm
in the USA check with the guys that run Stock car racing cars a lot of them will have the banding tools
and know of sources for good quality hose maybe local
place in OHIO called
http://www.summitracing.com/
may have the real good stuff in there online catalog
do it right no bigger pain than having a leak on even a short trip
Postby dunekahn » Wed Aug 19, 2015 1:07 pm
Thank you David, I'll likely have to piece together what I need from stuff that is close. I looked into Eric's suggestion above, the hoses for the XTZ and for the SZR are completely different and will be of no use.
I logged almost 120 miles this last Sunday, she ran beautifully in 100° weather. Those cooling hoses make me uncomfortable though.
D.
dunekahn
Users browsing this forum: Google [Bot] and 33 guests
