Seeking replacement plug for Secondary Carb
Postby Kcfirebolt » Fri Nov 13, 2015 3:27 pm
Somewhere on the back straight of Barber Motorsports Park, the brass plug which screws into the bottom of the secondary carb worked itself out and buried itself in the grass along the side of the track.
I know my riding is embarrassing, but jumping ship mid-lap is just mean.
Luckily, Gordon Hamilton was there with his Skorpion and loaned me his. I suspect he's gonna want it back, and I need a replacement.
I've discovered that Raptors have different carbs. Can't find a matching one other 660 Yamahas. Anyone know where I can find one?
Kcfirebolt
Re: Seeking replacement plug for Secondary Carb
Postby edfmaniac » Fri Nov 13, 2015 5:23 pm
The '94 XT600 is supposed to have the same carbs. Your part no. should be 7KF-14162-00-00.
http://www.yamahapartshouse.com/oempart ... carburetor
Postby Kcfirebolt » Mon Nov 16, 2015 4:24 pm
Thank you. Parts ordered (man, that's an expensive copper washer!).
Appreciate your help!
Charles
Kcfirebolt
Postby DAVID THOMPSON » Mon Nov 16, 2015 6:26 pm
the washers on a brake banjo connection are also very steep
Postby dandywarhol » Tue Nov 17, 2015 5:57 pm
Copper washers tend to be universally sized. Any good garage or hardware shop should stock them
Whale oil beef hooked
dandywarhol
Postby Kcfirebolt » Thu Dec 24, 2015 9:46 am
Hi guys,
The parts for the xt600 are very different. Not brass and not hollowed out. Does it need to be?
Any other ideas or suggestions? What brand of carb is the secondary carb?
Thanks for your help and Merry Christmas to all.
Kcfirebolt
Postby edfmaniac » Thu Dec 24, 2015 10:54 am
It's just a plug to stop fuel from pouring out. Do the threads not match up? I'm pretty sure both carbs are Teikei.
Postby Kcfirebolt » Tue Dec 29, 2015 12:42 pm
I did not take the plug from the dealership as it was so different from the stock one. So, you don't think the hollowed out "bowl" portion of the stock plug is needed? If not, It will be an easy fix.
Kcfirebolt
Postby edfmaniac » Tue Dec 29, 2015 3:24 pm
I don't think so. As long as the bolt or plug that you replace it with doesn't cover the fuel pathway coming from the primary carb, you should be good to go. Fuel will flow to the secondary carb only as fast as the fuel line can carry it. Any "bowl" or reserve space under the main jet is merely coincidental. It can't supply the jet with extra fuel without violating the laws of physics since it's not vented to atmosphere. IMO :D
Worst case scenario. Drill a hole in the middle of the new part to simulate the hollowed out part of the original.
Postby Kcfirebolt » Tue Dec 29, 2015 5:08 pm
Okay. That was kind of the conclusion the guy at the dealership came to in the end. We'll try it and see how it goes.
Thank you for the input.
Kcfirebolt
Users browsing this forum: Bing [Bot], Google [Bot] and 38 guests
